Multipilot32 branch and ChibiOS need developer ..
Re: Multipilot32 branch and ChibiOS need developer ..
The makefile of the various ChibiOS demos can already mix C and C++ files, you may just use that. Do you need an example C++ application with ChibiOS as template?
Anyway, please don't assume I am accepting tasks for your project, my personal bandwidth is limited, my job and this project already take most of it.
The best way to get help is to make specific and very focused questions regarding ChibiOS/RT in the context of your needs.
Don't worry Giovanni,
I need only a name of template that is yet available that i can use as starting point for my work .. , then we work on port wrapper , ecc , ecc , .. I think that you understand my idea ...
So in our implementation we need to use :
SerialPort,
Analog,
Digital IO,
SPI BUS,
I2C Bus. ( I know that is not yet officialy supported , but i need it, time for official support ? )
In future SD card.
DAC
and USB.
Best
Roberto
SerialPort,
Analog,
Digital IO,
SPI BUS,
In future SD card.
DAC
and USB.
Best
Roberto
do you have news about the template ?
Best
Roberto
Best
Roberto
I'm looking for users who use chibios with the multipilot32 and oilpan. I'm interrested to exchange experiences, dev problems...
My project starts, and currently I'm able to acquire and to parse gps data via serial port, to acquire gyro and accelerometer via spi port.
Currently I try to work in unstable version in order to use i2c driver (to acquire pressure BMP085 and magnetic compass).
I have tried to run my code (dev with 2.2.0) with unstable version 3426, and it doesn't work despite a good build. May be I have made some mistakes in makefile, mcuconf.h. (there is no multipilot32 directory in boards directory so i use OLIMEX_STM32_P107)
Does anyone has a template project to use unstable version with multipilot32 ?
Does anyone have project which able to use in the same time the serial, spi and i2C with multipilot32 and oilpan boards.
Cyrille
Cyrille
OLIMEX_STM32_P107 uses a very different STM32, probably you should start from OLIMEX_STM32_P103 and then customize it:
- Change the MCU type to STM32F10X_HD.
- Change the board name to MULTIPILOT.
- Change the xtals frequencies.
- Customize I/Os.
The problem is that the setting in mcuconf.h are calculated for a 8MHz crystal, you have to change them in order to obtain the correct final frequency from the PLL.
I believe board files for the multipilot have been created by Roberto a while ago, probably you should ask him.
- Customize I/Os.
Hi giovanni,
I have tried also OLIMEX_STM32_P103, but this boad apparently used only 3 serial ports, and I use 4 ports (GPS is in port 4), I have tried in mcuconf to set to the TRUE USART 4, but no result.
I have also tried to include to the boards directory of unstable version the MULTIPILOT32 directory available in ver 2.2.0, but no result.
This is a problem with many variables (mcuconf, board, code...) and I have not enough experience in chibios and STM32 to identy where is the problem or what is my error.
Find below my project config files
makefile:
mcuconf.h:
Multipilot32 board
Do you have some remarks ?
makefile:
# Define linker script file here
LDSCRIPT= $(PORTLD)/STM32F103xE.ld #ch.ld
# Imported source files
CHIBIOS = ../
include $(CHIBIOS)/boards/MULTIPILOT32/board.mk #OLIMEX_STM32_P107/board.mk #
include $(CHIBIOS)/os/hal/platforms/STM32F1xx/platform.mk
include $(CHIBIOS)/os/ports/GCC/ARMCMx/STM32F1xx/port.mk
include $(CHIBIOS)/os/kernel/kernel.mk
# include $(CHIBIOS)/test/test.mk
# C sources that can be compiled in ARM or THUMB mode depending on the global
# setting.
CSRC = $(PORTSRC) \
$(KERNSRC) \
$(TESTSRC) \
$(HALSRC) \
$(PLATFORMSRC) \
$(BOARDSRC) \
$(CHIBIOS)/os/various/evtimer.c \
$(CHIBIOS)/os/various/syscalls.c \
test.c \
Init.c \
debug.c \
GPS_parser.c \
IMU.c \mcuconf.h:
* HAL driver system settings.
#define STM32_SW STM32_SW_PLL
#define STM32_PLLSRC STM32_PLLSRC_HSE
#define STM32_PLLXTPRE STM32_PLLXTPRE_DIV1
#define STM32_PLLMUL_VALUE 9
#define STM32_PPRE1 STM32_PPRE1_DIV2
#define STM32_PPRE2 STM32_PPRE2_DIV2
#define STM32_ADCPRE STM32_ADCPRE_DIV4
#define STM32_USBPRE STM32_USBPRE_DIV1P5
#define STM32_MCO STM32_MCO_NOCLOCK
* ADC driver system settings.
#define STM32_ADC_USE_ADC1 TRUE
#define STM32_ADC_ADC1_DMA_PRIORITY 2
#define STM32_ADC_ADC1_IRQ_PRIORITY 5
* CAN driver system settings.
#define STM32_CAN_USE_CAN1 TRUE
#define STM32_CAN_CAN1_IRQ_PRIORITY 11
* EXT driver system settings.
#define STM32_EXT_EXTI0_IRQ_PRIORITY 6
#define STM32_EXT_EXTI1_IRQ_PRIORITY 6
#define STM32_EXT_EXTI2_IRQ_PRIORITY 6
#define STM32_EXT_EXTI3_IRQ_PRIORITY 6
#define STM32_EXT_EXTI4_IRQ_PRIORITY 6
#define STM32_EXT_EXTI5_9_IRQ_PRIORITY 6
#define STM32_EXT_EXTI10_15_IRQ_PRIORITY 6
#define STM32_EXT_EXTI16_IRQ_PRIORITY 6
#define STM32_EXT_EXTI17_IRQ_PRIORITY 6
#define STM32_EXT_EXTI18_IRQ_PRIORITY 6
#define STM32_EXT_EXTI19_IRQ_PRIORITY 6
* GPT driver system settings.
#define STM32_GPT_USE_TIM1 FALSE
#define STM32_GPT_USE_TIM2 FALSE
#define STM32_GPT_USE_TIM3 FALSE
#define STM32_GPT_USE_TIM4 FALSE
#define STM32_GPT_USE_TIM5 FALSE
#define STM32_GPT_USE_TIM8 FALSE
#define STM32_GPT_TIM1_IRQ_PRIORITY 7
#define STM32_GPT_TIM2_IRQ_PRIORITY 7
#define STM32_GPT_TIM3_IRQ_PRIORITY 7
#define STM32_GPT_TIM4_IRQ_PRIORITY 7
#define STM32_GPT_TIM5_IRQ_PRIORITY 7
#define STM32_GPT_TIM8_IRQ_PRIORITY 7
* ICU driver system settings.
#define STM32_ICU_USE_TIM1 FALSE
#define STM32_ICU_USE_TIM2 FALSE
#define STM32_ICU_USE_TIM3 FALSE
#define STM32_ICU_USE_TIM4 TRUE
#define STM32_ICU_USE_TIM5 FALSE
#define STM32_ICU_USE_TIM8 FALSE
#define STM32_ICU_TIM1_IRQ_PRIORITY 7
#define STM32_ICU_TIM2_IRQ_PRIORITY 7
#define STM32_ICU_TIM3_IRQ_PRIORITY 7
#define STM32_ICU_TIM4_IRQ_PRIORITY 7
#define STM32_ICU_TIM5_IRQ_PRIORITY 7
#define STM32_ICU_TIM8_IRQ_PRIORITY 7
* PWM driver system settings.
#define STM32_PWM_USE_ADVANCED TRUE
#define STM32_PWM_USE_TIM1 TRUE
#define STM32_PWM_USE_TIM2 FALSE
#define STM32_PWM_USE_TIM3 FALSE
#define STM32_PWM_USE_TIM4 FALSE
#define STM32_PWM_USE_TIM5 FALSE
#define STM32_PWM_USE_TIM8 FALSE
#define STM32_PWM_TIM1_IRQ_PRIORITY 7
#define STM32_PWM_TIM2_IRQ_PRIORITY 7
#define STM32_PWM_TIM3_IRQ_PRIORITY 7
#define STM32_PWM_TIM4_IRQ_PRIORITY 7
#define STM32_PWM_TIM5_IRQ_PRIORITY 7
#define STM32_PWM_TIM8_IRQ_PRIORITY 7
* SERIAL driver system settings.
#define STM32_SERIAL_USE_USART1 TRUE
#define STM32_SERIAL_USE_USART2 TRUE
#define STM32_SERIAL_USE_USART3 TRUE
#define STM32_SERIAL_USE_UART4 TRUE
#define STM32_SERIAL_USE_UART5 FALSE
#define STM32_SERIAL_USART1_PRIORITY 12
#define STM32_SERIAL_USART2_PRIORITY 12
#define STM32_SERIAL_USART3_PRIORITY 12
#define STM32_SERIAL_UART4_PRIORITY 12
#define STM32_SERIAL_UART5_PRIORITY 12
* SPI driver system settings.
#define STM32_SPI_USE_SPI1 TRUE
#define STM32_SPI_USE_SPI2 TRUE
#define STM32_SPI_USE_SPI3 FALSE
#define STM32_SPI_SPI1_DMA_PRIORITY 1
#define STM32_SPI_SPI2_DMA_PRIORITY 1
#define STM32_SPI_SPI3_DMA_PRIORITY 1
#define STM32_SPI_SPI1_IRQ_PRIORITY 10
#define STM32_SPI_SPI2_IRQ_PRIORITY 10
#define STM32_SPI_SPI3_IRQ_PRIORITY 10
#define STM32_SPI_DMA_ERROR_HOOK(spip) chSysHalt()
* UART driver system settings.
#define STM32_UART_USE_USART1 FALSE
#define STM32_UART_USE_USART2 TRUE
#define STM32_UART_USE_USART3 FALSE
#define STM32_UART_USART1_IRQ_PRIORITY 12
#define STM32_UART_USART2_IRQ_PRIORITY 12
#define STM32_UART_USART3_IRQ_PRIORITY 12
#define STM32_UART_USART1_DMA_PRIORITY 0
#define STM32_UART_USART2_DMA_PRIORITY 0
#define STM32_UART_USART3_DMA_PRIORITY 0
#define STM32_UART_DMA_ERROR_HOOK(uartp) chSysHalt()
* USB driver system settings.
#define STM32_USB_USE_USB1 TRUE
#define STM32_USB_LOW_POWER_ON_SUSPEND FALSE
#define STM32_USB_USB1_HP_IRQ_PRIORITY 6
#define STM32_USB_USB1_LP_IRQ_PRIORITY 14
* I2C driver system settings.
#define STM32_I2C_USE_I2C1 TRUE
#define STM32_I2C_USE_I2C2 TRUE
#define STM32_I2C_I2C1_IRQ_PRIORITY 10
#define STM32_I2C_I2C2_IRQ_PRIORITY 10
#define STM32_I2C_I2C1_DMA_PRIORITY 4
#define STM32_I2C_I2C2_DMA_PRIORITY 4
#define STM32_I2C_I2C1_DMA_ERROR_HOOK() chSysHalt()
#define STM32_I2C_I2C2_DMA_ERROR_HOOK() chSysHalt()
/* I2C1 */
#define STM32_I2C_I2C1_USE_GPT_TIM GPTD1
#define STM32_I2C_I2C1_USE_POLLING_WAIT TRUE
/* I2C2 */
#define STM32_I2C_I2C2_USE_GPT_TIM GPTD2
#define STM32_I2C_I2C2_USE_POLLING_WAIT TRUE
Multipilot32 board
* Setup for the Olimex STM33-P103 proto board.
* Board identifier.
#define BOARD_MULTIPILOT32
#define BOARD_NAME "Multipilot32"
* Board frequencies.
#define STM32_LSECLK 0
#define STM32_HSECLK 8000000
* MCU type, supported types are defined in ./os/hal/platforms/hal_lld.h.
#define STM32F10X_HD
* IO pins assignments.
#define GPIOA_BUTTON 0
#define GPIOA_SPI1NSS 4
#define GPIOB_SPI2NSS 12
#define GPIOC_USB_P 4
#define GPIOC_MMCWP 6
#define GPIOC_MMCCP 7
#define GPIOC_CAN_CNTL 10
#define GPIOC_USB_DISC 11
#define GPIOC_LED 12
* I/O ports initial setup, this configuration is established soon after reset
* in the initialization code.
* The digits have the following meaning:
* 0 - Analog input.
* 1 - Push Pull output 10MHz.
* 2 - Push Pull output 2MHz.
* 3 - Push Pull output 50MHz.
* 4 - Digital input.
* 5 - Open Drain output 10MHz.
* 6 - Open Drain output 2MHz.
* 7 - Open Drain output 50MHz.
* 8 - Digital input with PullUp or PullDown resistor depending on ODR.
* 9 - Alternate Push Pull output 10MHz.
* A - Alternate Push Pull output 2MHz.
* B - Alternate Push Pull output 50MHz.
* C - Reserved.
* D - Alternate Open Drain output 10MHz.
* E - Alternate Open Drain output 2MHz.
* F - Alternate Open Drain output 50MHz.
* Please refer to the STM32 Reference Manual for details.
* Port A setup.
* Everything input with pull-up except:
* PA0 - Normal input (BUTTON).
* PA2 - Alternate output (USART2 TX).
* PA3 - Normal input (USART2 RX).
#define VAL_GPIOACRL 0x8888BBB0 /* PA7...PA0 */
//#define VAL_GPIOACRH 0x888884B8 /* PA15...PA8 */ // Serial1 TX Serial1 RX
#define VAL_GPIOACRH 0x88888888 /* PA15...PA8 */ // Serial1 TX Serial1 RX DISATTIVATE
#define VAL_GPIOAODR 0xFFFFFFFF
* Port B setup.
* PB13 - Alternate output (MMC SPI2 SCK).
* PB14 - Normal input (MMC SPI2 MISO).
* PB15 - Alternate output (MMC SPI2 MOSI).
#define VAL_GPIOBCRL 0x88888888 /* PB7...PB0 */
#define VAL_GPIOBCRH 0xB4B88888 /* PB15...PB8 */
#define VAL_GPIOBODR 0xFFFFFFFF
* Port C setup.
* PC4 - Normal input because there is an external resistor.
* PC6 - Normal input because there is an external resistor.
* PC7 - Normal input because there is an external resistor.
* PC10 - Push Pull output (CAN CNTRL).
* PC11 - Push Pull output (USB DISC).
* PC12 - Push Pull output (LED).
#define VAL_GPIOCCRL 0x44848888 /* PC7...PC0 */
#define VAL_GPIOCCRH 0x88834B88 /* PC15...PC8 */ // SER 3 PC10 e PC11
#define VAL_GPIOCODR 0xFFFFFFFF
* Port D setup.
* PD0 - Normal input (XTAL).
* PD1 - Normal input (XTAL).
#define VAL_GPIODCRL 0x84B88844 /* PD7...PD0 */ // HO ATTIVATO SER 2 PD5-PD6
#define VAL_GPIODCRH 0x8888884B /* PD15...PD8 */ // HO ATTIVATO SER 3 PD8-PD9
#define VAL_GPIODODR 0xFFFFFFFF
* Port E setup.
#define VAL_GPIOECRL 0x88888888 /* PE7...PE0 */
#define VAL_GPIOECRH 0x88888888 /* PE15...PE8 */
#define VAL_GPIOEODR 0xFFFFFFFF
#if !defined(_FROM_ASM_)
#ifdef __cplusplus
extern "C" {
void boardInit(void);
#ifdef __cplusplus
#endif /* _FROM_ASM_ */
#endif /* _BOARD_H_ */
No remarks if the board has a 8MHz crystal.
You have to program correctly the UART pins in board.h as alternate or the UARTs will not output any data. I see commented lines there, probably that is not correct.
Your problem is that you have to create a correct board.h file, correct in all its parts, the other configuration files are less important.
I follow your advices, and I work on board.h for MULTIPILOT32. Concerning the GPIO configuration I have some difficulties to understand what is alternate function. I have understood that there is various function for each pin, and it is possible to attibuate specific function to pin (remap). what is the difference beween "Alternate push-pull output" and "push-pull output " for GPIO config (VAL_GPIOxCRL VAL_GPIOxCRH).
What is the correct configuration for :
- PWM
- SPI SCK, MISO MOSI (in master mode)
- UART Tx, Rx
- I2C
Cyrille
- PWM
- UART Tx, Rx
- I2C
Cyrille
"push-pull output" is for for pins used as GPIOs while "Alternate push-pull output" is for pins used as the alternate functions, all the peripherals you mentioned are alternate functions.
Cyrille, I recommend to study the STM32 Reference Manual carefully (and the Datasheet for pin assignments), while the HAL abstracts a lot of things, working on an embedded application still requires strong knowledge of the hardware you are using. Remember, manuals are your best friends when it comes at understanding how it works and, more often, why it does not work
