SPI on STM32F1x
toxygen
SPI on STM32F1x
Post by toxygen »
by looking at the example board config (olimex p107), I can see that spi miso and mosi are configured as follows:
 * PC11 - Input with PU     (SPI3 MISO).
 * PC12 - Alternate output  (SPI3 MOSI).
however, when looking in testhal/STM32F1xx/SPI/main.c I see the following commands:
 palSetPadMode(IOPORT1, 6, PAL_MODE_STM32_ALTERNATE_PUSHPULL);     /* MISO.*/
palSetPadMode(IOPORT1, 7, PAL_MODE_STM32_ALTERNATE_PUSHPULL);     /* MOSI.*/
I'm using the 2.6.1 release. Can you please clarify which config is correct? I suppose the one with digital input, but I would rather have it confirmed.
Re: SPI on STM32F1x
HI,
The one with digital input is correct, it is possible that the one with alternate is working too, I have to verify.
goeck
Re: SPI on STM32F1x
Post by goeck »
Hey,
just a short question on this. I want to use PA8 as MCO pin on my STM32F0-Discovery, so I set up everything but had to alter definitions in my board.h. All works.
I now just want to leave bord.h as is from repository and set up in an init funtion in main(). So I use
palSetPadMode(GPIOA, 8, PAL_MODE_STM32_ALTERNATE_PUSHPULL);
but the compiler telles me function is not defined.
Can't I chnage pin behaviour this deep after board init?
Cheers
Stefan
Re: SPI on STM32F1x
Is it an F0 or an F1? that line works for the F1 only which has the old GPIO unit. For all the other STM32s it is:
palSetPadMode(GPIOA, 8, PAL_MODE_ALTERNATE(N));
Where N is the number of the alternate function, see the data sheet.
goeck
Re: SPI on STM32F1x
Post by goeck »
Awesome, thanks again for the help, Giovanni!
