It is not complete (no HAL ports) but it manages to run code succesfully.
Port is for NUC120LE3AN MCU from Nuvoton on a NUC120-TINY-SDK board I have received from them some time back.
It is a Cortex M0.
So, basically I have copied all directories related to LPC11xx and made new NUC120 subdirectories.
os\ports\GCC\ARMCMx\NUC120:
vectors.c - does not need any change because LPC11xx and NUC120 have same exception vectors. CortexM0 exception
vectors (mandatory ones) are the same. NUC120 and LPC11xx have same number of other 31 exception vectors.
Since I didn't have to use any of them, I didn't change the names to human readable ones and left the same
names as in LPC11xx file. So basically, no change needed.
cmparams.h - stays the same.
os\hal\platforms\NUC120:
For this to workI didn't port fully PAL drivers. I also used CMSIS files for implemeting hal_lld functions.
I have removed almost all defines from hal_lld header file, except function defintions.
I have modified platform.mk to not compile PAL, SPI, Serial, etc drivers but to compile DrvGPIO and DrvSYS
from CMSIS. Added header file for NUC120 to define ports, pins, registers, etc. core_m0.h stays the same.
So make does:
PLATFORMSRC = ${CHIBIOS}/os/hal/platforms/NUC120/hal_lld.c \
${CHIBIOS}/os/hal/platforms/NUC120/DrvSYS.c \
${CHIBIOS}/os/hal/platforms/NUC120/DrvGPIO.c
And hal_lld.c has:
void hal_lld_init(void) {
/* SysTick initialization using the system clock.*/
NVICSetSystemHandlerPriority(HANDLER_SYSTICK, CORTEX_PRIORITY_SYSTICK);
SysTick->LOAD = 50000000 / CH_FREQUENCY - 1;
SysTick->VAL = 0;
SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk |
SysTick_CTRL_ENABLE_Msk |
SysTick_CTRL_TICKINT_Msk;
* @brief NUC120 clocks and PLL initialization.
* @note All the involved constants come from the file @p board.h.
* @note This function must be invoked only after the system reset.
* @special
void nuc120_clock_init(void) {
int t;
DrvSYS_SetOscCtrl(E_SYS_XTL12M, 1); // Enable External 12Mhz Crystal
for(t=0;t<100;++t); // Delay for clock to stabilize
DrvSYS_SetPllSrc(E_DRVSYS_EXT_12M);
DrvSYS_SetPLLPowerDown(0);
DrvSYS_Open (12000, 50000); // Run System Clock @ 50Mhz from external 12Mhz crystal
boards\NUC120:
boards.h stays the same. In real port #define's should be removed but since we don't use them..
board.c is:
* Early initialization code.
* This initialization must be performed just after stack setup and before
* any other initialization.
void __early_init(void) {
nuc120_clock_init();
* Board-specific initialization code.
void boardInit(void) {
* Extra, board-specific, initializations.
demos/NUC120:
Linker file is the same except above SECTIONS it is changed to:
* NUC120LE3AN memory setup.
__main_stack_size__ = 0x0100;
/* __process_stack_size__ = 0x0100; */
/*__stacks_total_size__ = __main_stack_size__ + __process_stack_size__; */
__stacks_total_size__ = __main_stack_size__;
MEMORY
flash : ORIGIN = 0x00000000, LENGTH = 0x00020000
ram : ORIGIN = 0x20000000, LENGTH = 0x00004000
__ram_start__ = ORIGIN(ram);
__ram_size__ = LENGTH(ram);
__ram_end__ = __ram_start__ + __ram_size__;
SECTIONS
halconf.h is changed to remove all drivers.
main.c:
#include "ch.h"
#include "hal.h"
#include "test.h"
#include "DrvGPIO.h"
(void)arg;
chRegSetThreadName("blinker1");
unsigned char t;
uint32_t i;
while(TRUE)
for(t = 0; t<3;++t)
DrvGPIO_ClrBit(GPB, 0);
chThdSleepMilliseconds(10);
DrvGPIO_SetBit(GPB, 0);
chThdSleepMilliseconds(500);
static WORKING_AREA(waThread2, 128);
static msg_t Thread2(void *arg) {
(void)arg;
chRegSetThreadName("blinker2");
while(TRUE)
chThdSleepMilliseconds(1000);
* Application entry point.
int main(void) {
uint32_t i,t;
DrvGPIO_Open(GPB, 0, IO_OUTPUT);
* Creates the blinker threads.
chThdCreateStatic(waThread2, sizeof(waThread2), NORMALPRIO, Thread2, NULL);
i = 0;
while (TRUE) {
i = (i + 1) & 15;
So, with above you have ChibiOS running on NUC120 hardware; it should run on all NUC1xx devices except linker
script should be changed for various devices and possibly vectors.c.
Of course, port is not complete; hal_lld.h should maybe be done with #defines to define system setup
and not use CMSIS for Clock Setting. Allow for internal RC osciallator.
Vectors.c should be changed so that exception vectors have real name for NUC1xx devices for developers to use.
board.c setup should also be done, etc.
Since I had to use Windows7 project was compiled as follows:
- Used Windows XP mode (virtual machine coming with Win7) and installed Yagarto latest ARM GCC / binutils.
Copied executable elf back to Windows 7.
Used CoFlash (from Coocox) to load elf and flash the board since it supports Nu-Link programmer
that comes with the board.
About CMSIS:
Actually what is community feel about using CMSIS library instead of accessing MCU directly? For example like I
did in activating external crystal, setting PLL and using it as a system clock? I find it easier since
API is standardized and it is quicker to do.
I wouldn't mind working on this more to make it official port and contribute to the project, so let me know what needs to be done,
any suggestions to the above I have written, etc and I can find time to do it...
