[DONE] STM32F107 USB hangs
panacekcz
Post by panacekcz »
I am trying to use USB serial. I use custom board with STM32F107, 16 MHz HSE, ChibiOS 2.6.2, GCC.
The program I use is based on the USB demo
int main(void) {
  sduObjectInit(&SDU1);
  sduStart(&SDU1, &serusbcfg);
  chThdSleepMilliseconds(1000);
  for(;;){
   //could be anything here (echoing the byte, blinking led, ...)
   chnGetTimeout(&SDU1, 1000);
I use this testing script (in Linux):
while true
do echo "X" > /dev/ttyACM0 # Open the serial USB and close it again
echo "OK" # Write to the terminal to see that it works
done
The script works for a random number of cycles and then starts to report IO errors - it hangs when opening the file (there is some communication when opening it).
(If I open cat /dev/ttyACM0 in another terminal, then this communication does not happen every time the file is opened for writing and everything works fine. So I think it never occurs when transferring data but only when opening and closing.)
The main program on the board continues to run normally (blinking LED or whatever).
When I pause the program in debugger after it hangs, I see that usbp->ep0state is USB_EP0_SENDING_STS and usbp->transmitting is (mostly) 1. I suspect this can be the problematic state because if I pause it before it hangs, usbp->ep0state is usually USB_EP0_WAITING_SETUP. But I don't understand those states very much.
At first I used -Os and running from RAM, but now I use -O0 and the common linker script and the problem happens too although usually later than when running from RAM.
I don't know how to continue now, maybe if someone could try to reproduce it. Before sending this post I tried using as much original source from /ChibiOS_2.6.2/testhal/STM32F1xx/USB_CDC_F107 as possible, I only changed the LED pin, board.c and board.h, and clock settings in mcuconf.h. It can run OK for some minutes, but eventually hangs too.
Re: STM32F107 USB hangs
The USB driver has internally a worker thread operating at very low priority, if the main() thread never goes into a sleep state then the worker thread is starved and the USB does not work.
Could this be your case?
Also, are the debugging options enabled in chconf.h?
panacekcz
Post by panacekcz »
all the CH_DBG_ macros in chconf.h are TRUE.
I tried more variants of the main thread. It can be:
for(;;){
 palTogglePad(GPIOC, GPIOC_LED13);
That is not much activity and the problem still happens. I even tried:
chThdExit(0);
Or setting the USB thread priority to HIGHPRIO.
I also simplified the BASH test script, so that it does not send any data (so the application doesn't have to process them).
x=0
while true
do touch /dev/ttyACM0
echo "OK" $x
x=$[x+1]
done
It also shows the number of open/close cycles, which is random, but seems to depend on compile options and maybe other things.
The example in ChibiOS_2.6.2/testhal/STM32F1xx/USB_CDC_F107 (with -O2) can survive 10000 cycles, in the "minimal program" I created, with -Os or -O0, it is around 100, and the program I originally had (with -Os too) usually died before 10 cycles which is why I started to investigate this.
Or is -Os not supported? With -O2 I can probably get enough cycles not to notice the problem in practice but I wanted to save space because it is a bootloader.
Compiler options should not matter.
Does your application consume the X you send? are you sure to consume all the sent X? meaning you have to attempt a read until the queue is reported empty.
panacekcz
Post by panacekcz »
Hi, thanks for the replies!
It's true I am not consuming the X, but with the second version of the script, I am not even sending them. I am just opening and closing the file.
But to be 100% sure, I changed the main loop to this:
for(;;){
 chnGetTimeout(&SDU1, TIME_INFINITE);
I can't imagine a safer version - it reads all the data and suspends when there are not any.
Furthermore, to be sure I am not too fast, I inserted a sleep to the test script.
#!/bin/bash
x=0
while true
sleep 1
echo "OK" $x
x=$[x+1]
done
Now it is not faster than one open/close per second, not sending any real data. And it still fails after ~200 cycles.
I am getting more convinced that there is always some probability that opening/closing would trigger the error. And in the program I was developing it got so high I started noticing it even when communicating by hand.
Before submitting this post I even tried inserting another 1-second sleep between opening and closing the file. It worked for 800 cycles (half an hour) but then failed.
Also, here is what I get from usbmon, if it could help somehow.
A successful open/close.
ffff88006ae30d80 3322959924 S Ii:6:011:2 -115:128 8 <
ffff8800637f3300 3322959942 S Co:6:011:0 s 21 22 0003 0000 0000 0
ffff8800637f3300 3322961428 C Co:6:011:0 0 0
ffff88007a5fa500 3322961468 S Bi:6:011:1 -115 128 <
ffff88007a5faec0 3322961481 S Bi:6:011:1 -115 128 <
ffff88007a8b3800 3322961485 S Bi:6:011:1 -115 128 <
ffff88007a8a0f00 3322961488 S Bi:6:011:1 -115 128 <
ffff880036b29680 3322961493 S Bi:6:011:1 -115 128 <
ffff880036b29980 3322961498 S Bi:6:011:1 -115 128 <
ffff880036b29800 3322961502 S Bi:6:011:1 -115 128 <
ffff880036b29ec0 3322961505 S Bi:6:011:1 -115 128 <
ffff88007a04ad80 3322961510 S Bi:6:011:1 -115 128 <
ffff88007a5fa2c0 3322961514 S Bi:6:011:1 -115 128 <
ffff88007a5fa440 3322961517 S Bi:6:011:1 -115 128 <
ffff88007a5fac80 3322961522 S Bi:6:011:1 -115 128 <
ffff88007a5faa40 3322961526 S Bi:6:011:1 -115 128 <
ffff88007a5fa380 3322961530 S Bi:6:011:1 -115 128 <
ffff88007a8a06c0 3322961534 S Bi:6:011:1 -115 128 <
ffff88007a5fa140 3322961537 S Bi:6:011:1 -115 128 <
ffff8800637f3300 3322961716 S Co:6:011:0 s 21 22 0000 0000 0000 0
ffff8800637f3300 3322962425 C Co:6:011:0 0 0
ffff88006ae30d80 3322963424 C Ii:6:011:2 -2:128 0
ffff88007a5fa500 3322964423 C Bi:6:011:1 -2 0
ffff88007a5faec0 3322965422 C Bi:6:011:1 -2 0
ffff88007a8b3800 3322966423 C Bi:6:011:1 -2 0
ffff88007a8a0f00 3322967424 C Bi:6:011:1 -2 0
ffff880036b29680 3322968422 C Bi:6:011:1 -2 0
ffff880036b29980 3322969403 C Bi:6:011:1 -2 0
ffff880036b29800 3322970421 C Bi:6:011:1 -2 0
ffff880036b29ec0 3322971433 C Bi:6:011:1 -2 0
ffff88007a04ad80 3322972433 C Bi:6:011:1 -2 0
ffff88007a5fa2c0 3322973424 C Bi:6:011:1 -2 0
ffff88007a5fa440 3322974425 C Bi:6:011:1 -2 0
ffff88007a5fac80 3322975424 C Bi:6:011:1 -2 0
ffff88007a5faa40 3322976422 C Bi:6:011:1 -2 0
ffff88007a5fa380 3322977424 C Bi:6:011:1 -2 0
ffff88007a8a06c0 3322978423 C Bi:6:011:1 -2 0
ffff88007a5fa140 3322979423 C Bi:6:011:1 -2 0
1 second later, a problem occurs when closing (note the 5-second delay and -2 response from ep 0)
ffff88006ae30d80 3323983377 S Ii:6:011:2 -115:128 8 <
ffff88006aaf5b00 3323983393 S Co:6:011:0 s 21 22 0003 0000 0000 0
ffff88006aaf5b00 3323984450 C Co:6:011:0 0 0
ffff88007a5fa500 3323984474 S Bi:6:011:1 -115 128 <
ffff88007a5faec0 3323984479 S Bi:6:011:1 -115 128 <
ffff88007a8b3800 3323984481 S Bi:6:011:1 -115 128 <
ffff88007a8a0f00 3323984483 S Bi:6:011:1 -115 128 <
ffff880036b29680 3323984486 S Bi:6:011:1 -115 128 <
ffff880036b29980 3323984488 S Bi:6:011:1 -115 128 <
ffff880036b29800 3323984490 S Bi:6:011:1 -115 128 <
ffff880036b29ec0 3323984493 S Bi:6:011:1 -115 128 <
ffff88007a04ad80 3323984495 S Bi:6:011:1 -115 128 <
ffff88007a5fa2c0 3323984497 S Bi:6:011:1 -115 128 <
ffff88007a5fa440 3323984499 S Bi:6:011:1 -115 128 <
ffff88007a5fac80 3323984501 S Bi:6:011:1 -115 128 <
ffff88007a5faa40 3323984504 S Bi:6:011:1 -115 128 <
ffff88007a5fa380 3323984506 S Bi:6:011:1 -115 128 <
ffff88007a8a06c0 3323984508 S Bi:6:011:1 -115 128 <
ffff88007a5fa140 3323984511 S Bi:6:011:1 -115 128 <
ffff88006aaf5b00 3323984591 S Co:6:011:0 s 21 22 0000 0000 0000 0
ffff88006aaf5b00 3328982559 C Co:6:011:0 -2 0
ffff88006ae30d80 3328983555 C Ii:6:011:2 -2:128 0
ffff88007a5fa500 3328984557 C Bi:6:011:1 -2 0
ffff88007a5faec0 3328985557 C Bi:6:011:1 -2 0
ffff88007a8b3800 3328986554 C Bi:6:011:1 -2 0
ffff88007a8a0f00 3328987554 C Bi:6:011:1 -2 0
ffff880036b29680 3328988553 C Bi:6:011:1 -2 0
ffff880036b29980 3328989556 C Bi:6:011:1 -2 0
ffff880036b29800 3328990553 C Bi:6:011:1 -2 0
ffff880036b29ec0 3328991554 C Bi:6:011:1 -2 0
ffff88007a04ad80 3328992554 C Bi:6:011:1 -2 0
ffff88007a5fa2c0 3328993555 C Bi:6:011:1 -2 0
ffff88007a5fa440 3328994552 C Bi:6:011:1 -2 0
ffff88007a5fac80 3328995556 C Bi:6:011:1 -2 0
ffff88007a5faa40 3328996556 C Bi:6:011:1 -2 0
ffff88007a5fa380 3328997557 C Bi:6:011:1 -2 0
ffff88007a8a06c0 3328998554 C Bi:6:011:1 -2 0
ffff88007a5fa140 3328999555 C Bi:6:011:1 -2 0
All following attempts fail.
ffff88006ae30d80 3330005302 S Ii:6:011:2 -115:128 8 <
ffff88006aaf5b00 3330005319 S Co:6:011:0 s 21 22 0003 0000 0000 0
ffff88006aaf5b00 3335006681 C Co:6:011:0 -2 0
ffff88006aaf5b00 3335006741 S Co:6:011:0 s 21 22 0000 0000 0000 0
ffff88006aaf5b00 3340006799 C Co:6:011:0 -2 0
ffff88006ae30d80 3340007796 C Ii:6:011:2 -2:128 0
Vlastimil Dort
Not sure how to read those logs. What is the message sent on close? there is no real open/close operations, it must be some CDC-specific message, may be an unimplemented message that then hangs the endpoint.
Note that not all the possible CDC messages are implemented in Serial_USB.
panacekcz
Post by panacekcz »
Hi, thanks for the reply.
I looked it up in linux driver source. It is SET_CONTROL_LINE_STATE (0x22) request.
In acm_tty_open it sets it to 3 (ACM_CTRL_DTR | ACM_CTRL_RTS), in acm_port_down it sets it to 0.
I see this is handled in sduRequestsHook with zero-sized response. This takes it to the USB_EP0_SENDING_STS state.
I tried to inspect the usb driver by debugger and UART outputs and this came to my attention
static void otg_epin_handler(USBDriver *usbp, usbep_t ep) {
  stm32_otg_t *otgp = usbp->otg;
  uint32_t epint = otgp->ie[ep].DIEPINT;
  otgp->ie[ep].DIEPINT = 0xFFFFFFFF;
I think you might be missing interrupts here. I tried:
  otgp->ie[ep].DIEPINT = epint;
Seems to solve the problem!
Vlastimil Dort
I need to go examine that code carefully, marking the thread as TODO.
Re: [TODO] STM32F107 USB hangs
Thanks for finding, the fix has been committed on the repositor and tracked as bug #457. There was another similar error in otg_epout_handler(), I fixed this one as well.
Could you confirm that the current code is working for you?
panacekcz
Re: [DONE] STM32F107 USB hangs
Post by panacekcz »
now everything works as expected. Thank you.
Vlastimil Dort
