Our program has unpredictable behavior on some instances. but if I add a line that should not make a difference program works.
I think this is because of optimization level. It might go away if I change optimization level from 3 to 2.
Does anyone know how to do so?
Thank you.
Change gcc optimization level
Re: Change gcc optimization level
HI,
Edit the Makefile in the project, the level is 2 by default (and note, you should not have instabilities at any optimization level, you risk to hide the real problem).
Thanks for the help. Yes you were right. This did not make much difference.
And I still need help. It would be great if I can get help with this.
I have following function
Here if I change following code
to following
The function would not work. With first code, STM32 detects PN532 but with second it does not.
Similarly if I remove "ghConsoleprint("h1\n");" than PN532 does not perform peer to peer detection/communication error rate increases.
I am not sure what could be the problem.
Thank you.
boolean sendCommandCheckAck_fcn(uint8_t *cmd, uint8_t cmdlen, uint16_t timeout) {
uint16_t timer = 0;
uint8_t x;
// write the command
spiwritecommand_fcn(cmd, cmdlen);
// Wait for chip to say its ready!
while (readspistatus_fcn() != PN532_SPI_READY) {
if (timeout != 0) {
timer+=10;
if (timer > timeout)
return FALSE;
delay_ms(10);
// read acknowledgement
if (!spi_readack_fcn()) {
return FALSE;
ghConsoleprint("h2\n");
timer = 0;
x=readspistatus_fcn();
while (x != PN532_SPI_READY) {
if (timeout != 0) {
timer+=10;
return FALSE;
delay_ms(10);
return TRUE; // ack'd command
to following
Thank you.
I don't recognize any of the functions you call in that code, how am I supposed to help? also, please keep requests on the appropriate forums.
