SD Card Timeout on read - STM32F207VCT6
dismirlian
Been thanked: 16 times
Post by dismirlian »
Hello, I am trying to read a SD card using the MMC over SPI driver.
I am having a sporadic timeout in the function mmcSequentialRead, which I copy below for convenience. The MCU doesn't receive the 0xFE. I tried waiting in an infinite loop, but the 0xFE never arrives. The problem is not very frequent (for example, it appears when I try to read files larger than 100kB).
Has someone seen a similar problem? What could be the cause?
Thank you very much for your help.
Diego.
bool_t mmcSequentialRead(MMCDriver *mmcp, uint8_t *buffer) {
  int i;
  chDbgCheck((mmcp != NULL) && (buffer != NULL), "mmcSequentialRead");
  if (mmcp->state != BLK_READING)
    return CH_FAILED;
  for (i = 0; i < MMC_WAIT_DATA; i++) {
    spiReceive(mmcp->config->spip, 1, buffer);
    if (buffer[0] == 0xFE) {
      spiReceive(mmcp->config->spip, MMCSD_BLOCK_SIZE, buffer);
      /* CRC ignored. */
      spiIgnore(mmcp->config->spip, 2);
      return CH_SUCCESS;
  /* Timeout.*/
  spiUnselect(mmcp->config->spip);
  spiStop(mmcp->config->spip);
  mmcp->state = BLK_READY;
  return CH_FAILED;
Re: SD Card Timeout on read - STM32F207VCT6
Could you try another brand/type of card?
dismirlian
Thank you for the suggestion Giovanni. I've done some further testing, and I also get some read errors, so I believe I have an electrical problem; I'll keep you posted...
Thanks!
Diego.
dismirlian
I've finally had time to look at this problem, and found that the culprit was a wrong TVS soldered to the SPI lines (too much capacitance).
Thanks for your support Giovanni.
Diego.
