STM32F4 Discovery UART 2
Faisal Mehmood
Post by Faisal Mehmood »
Hi
I need to use UART module of STM32F4 discovery kit. I have been going through the documentations but am unable to get the UART module running.
Here is the configuration instance. For simplicity, i have disabled all the callbacks.
static UARTConfig uartcfg = {
   NULL,                    /* End of Transmission buffer callback               */
   NULL,                    /* Physical end of transmission callback             */
   NULL,                    /* Receive buffer filled callback                    */
   NULL,                   /* Char received while out of the UART_RECEIVE state */
   NULL,                    /* Receive error callback                            */
   9600,                     /* Baudrate                                          */
   0,                       /* cr1 register values                               */
   0,                       /* cr2 register values                               */
   0                        /* cr3 register values                               */
Setting TX and RX pins mode:
  /* PD5 == USART2 TX PIN ;   PD == USART2 RX PIN */
  palSetPadMode(GPIOD, 5 , PAL_MODE_ALTERNATE(7));
  palSetPadMode(GPIOD, 6 , PAL_MODE_ALTERNATE(7));
/*   UART 2 Initialization and stuff */
  uartStart(&UARTD2, &uartcfg);
Continuously transmit a string with 500mSec breaks.
while(1)
uartStartSend(&UARTD2,13,"Started\n");
chThdSleepMilliseconds(500);
Can someone please point out the mistake(s) I am making.
The device is working. There is an led that keeps blinking, indicating that the program is executing fine.
Re: STM32F4 Discovery UART 2
If you don't have special requirements I suggest to try the Serial driver instead of the UART driver. It is a traditional serial driver with circular queues and is usually easier to use.
If you really need to use the UART driver please give a try to the demo located under ./testhal/STM32F4xx/UART if you haven't seen it yet.
Faisal Mehmood
Thanks for the suggestion. My requirement is just simple transmission and reception so I guess serial driver would do.
I have been searching the web for an example regarding the serial driver. Actually its my final year project and i am running out of time. Can you please tell me how can I get the serial (or UART) driver running in minimum time?
An example would be very helpful.
cheers
Most demos contain examples of the serial driver...
You start the driver:
   * Activates the serial driver 2 using the driver default configuration.
   * PA2(TX) and PA3(RX) are routed to USART2.
  sdStart(&SD2, NULL);
  palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7));
  palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7));
Then you can use the I/O channers API to read and write: http://chibios.sourceforge.net/html/gro ... n_e_l.html
Faisal Mehmood
sorry if this is a noob-ish question but I can't see how to use Rx buffer full and Tx buffer empty interrupts??
There is a single option (bit rate) in the serial Config structure. How to set interrupts??
You don't need to set anything, just read and write from SD2. Low level details are hidden.
Faisal Mehmood
Actually I have to control a motor's speed depending on what I receive on the serial port. So I want to have an interrupt like function that would inform me whenever a byte arrives on the serial port.
One last question. Will the SD2 notify me by itself or I will have to poll??
Cheers
The serial driver can generate something called events, see here: viewtopic.php?f=2&t=1348
Faisal Mehmood
Thanx a lot Giovanni!
Actually I have very limited knowledge of operating system stuff like thread, working area, events etc that's why I had to ask so many basic questions.
Cheers
