Application crash
diurpaneus
Application crash
Post by diurpaneus »
I seem to have a strange crash in my application. Whenever the CPU executes the instruction ldr r3, [r3, #0] it goes to the unhandled exception function.
If I jump over this instruction the code executes with no problem. The value contained in r3 seems to be a valid address. Here is the screenshots of the code and the memory dump.
Here's the lst file for this particular function:
1030                 _ads_lld_calculate_coeff:
 1031                 .LFB59:
 1032                    .loc 2 227 0
 1033                    .cfi_startproc
 1034                    @ args = 0, pretend = 0, frame = 16
 1035                    @ frame_needed = 0, uses_anonymous_args = 0
 1036 0000 00B5           push   {lr}
 1037                 .LCFI17:
 1038                    .cfi_def_cfa_offset 4
 1039 0002 85B0           sub   sp, sp, #20
 1040                 .LCFI18:
 1041                    .cfi_def_cfa_offset 24
 1042                    .loc 2 235 0
 1043 0004 0C4B           ldr   r3, .L58
 1044 0006 1B68           ldr   r3, [r3, #0]
 1045 0008 1846           mov   r0, r3
 1046                    .cfi_offset 14, -4
 1047 000a FFF7FEFF       bl   fix16_from_int
 1048 000e 0390           str   r0, [sp, #12]
 1049                    .loc 2 236 0
 1050 0010 0A4B           ldr   r3, .L58+4
 1051 0012 1B68           ldr   r3, [r3, #0]
 1052 0014 1846           mov   r0, r3
 1053 0016 FFF7FEFF       bl   fix16_from_int
 1054 001a 0290           str   r0, [sp, #8]
 1055                    .loc 2 237 0
 1056 001c 074B           ldr   r3, .L58+4
 1057 001e 1B68           ldr   r3, [r3, #0]
 1058 0020 1846           mov   r0, r3
 1059 0022 0399           ldr   r1, [sp, #12]
 1060 0024 FFF7FEFF       bl   fix16_div
 1061 0028 0190           str   r0, [sp, #4]
 1062                    .loc 2 238 0
 1063 002a 0198           ldr   r0, [sp, #4]
 1064 002c FFF7FEFF       bl   fix16_to_int
 1065 0030 0090           str   r0, [sp, #0]
 1066                    .loc 2 240 0
 1067 0032 05B0           add   sp, sp, #20
 1068 0034 00BD           pop   {pc}
Here are the variables in the map file:
COMMON         0x20000610       0x40 objs/ads7843_lld.o
                0x20000610                g_det
                0x20000614                g_touchMatrix
                0x20000628                g_Y2Det
                0x2000062c                g_u16X2
                0x20000630                g_X3Det
                0x20000634                g_u16Y2
                0x20000638                g_Y3Det
                0x2000063c                g_X1Det
                0x20000640                g_u16Y1
                0x20000642                g_u16X1
                0x20000644                g_Y1Det
                0x20000648                g_u16X3
                0x2000064a                g_u16Y3
                0x2000064c                g_X2Det
                0x20000650                . = ALIGN (0x4)
                0x20000650                _bss_end = .
                0x20000650                PROVIDE (end, .)
                0x20000650                _end = .
                0x20000650                __heap_base__ = _end
                0x20001800                __heap_end__ = (__ram_end__ - __stacks_total_size__)
OUTPUT(TempBoard.elf elf32-littlearm)
Re: Application crash
Strange, it would be helpful to know which is the triggered exception, by default all the unhandled exceptions go into the same handler.
diurpaneus
I don't really know how to find out which exception is triggered. Could you please tell me how to find out?
You just have to redefine the vector names defined in vectors.c, if you give a function the same name it replaces the default vector. It should be one of the following:
void NMIVector(void);
void HardFaultVector(void);
void MemManageVector(void);
void BusFaultVector(void);
void UsageFaultVector(void);
