ADC1 configuration
Nemesis2065
ADC1 configuration
Post by Nemesis2065 »
I am currently working on the ADC1 on the STM32F4 discovery board. The goal is to get the temp info of the board on ADC1 and also connect some infrared telemeters (Sharp GP2D12).
For this I want to use the ADC1 : PC1 for the internal temp sensor and PC2, PC3, PC4 for the telemeters.
For test purpose, I want to put the RED led "ON" when the value on these pins is greater than 1500mV.
The problem is when I put 3V on the pins PC2, PC3 or PC4, it doesn't put the RED led "ON".
I send also the values on the Uart, but have some random values of the order of 40mV. (even if the pins are connected or not to 3V)
I tried different solutions from different examples, but still without success :
https://github.com/mabl/ChibiOS/blob/master/demos/ARMCM4-STM32F407-DISCOVERY/main.c
https://github.com/Mathias-L/STM32F4-Discovery-example-code/blob/master/myADC.c
https://github.com/nt4t/Chibios-STM32F051-DISCOVERY-adc-shell-example/blob/master/main.c
Could you tell me if my configuration is correct ?
My Eclipse project is modified compared to the ChibiOS project from the Demo. I have 2 files for the ADC config :
adc_cfg.c :
adcsample_t ADC1_Samples[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
const ADCConversionGroup ADC1_grpcfg =
   FALSE,                              // set to TRUE if need circular buffer, set FALSE otherwise
   ADC_GRP1_NUM_CHANNELS,               // number of channels
   ADC1_Cbk,                            // callback function
   NULL,                               // CR1 register content
   // HW dependent part
   0,                                  // CR2 register content
   ADC_CR2_SWSTART,                      // SMRP1 register content
   ADC_SMPR1_SMP_SENSOR(ADC_SAMPLE_56) | ADC_SMPR1_SMP_AN12(ADC_SAMPLE_56) | ADC_SMPR1_SMP_AN13(ADC_SAMPLE_56) | ADC_SMPR1_SMP_AN14(ADC_SAMPLE_56),
   ADC_SQR1_NUM_CH(ADC_GRP1_NUM_CHANNELS),    // SQR1 register content. Set channel sequence length
   0,                                  // SQR2 register content
   ADC_SQR3_SQ1_N(ADC_CHANNEL_SENSOR) | ADC_SQR3_SQ2_N(ADC_CHANNEL_IN12) | ADC_SQR3_SQ3_N(ADC_CHANNEL_IN13) | ADC_SQR3_SQ4_N(ADC_CHANNEL_IN14)
adc_cfg.h :
 * DEFINES
// Total number of channels to be sampled by a single ADC operation.
#define ADC_GRP1_NUM_CHANNELS   4
// Depth of the conversion buffer : channels are sampled four times each.
#define ADC_GRP1_BUF_DEPTH      4
 * EXTERN
extern const ADCConversionGroup ADC1_grpcfg;
extern adcsample_t ADC1_Samples[];
 * PROTOTYPES
void ADC1_Cbk(ADCDriver *adcp, adcsample_t *buffer, size_t n);
Then I have an initialization function called at the beginning of the main :
init.c :
void Init_Drivers(void)
   * Initializes the ADC driver 1 for pins PC1,2,3,4 and enable the thermal sensor.
   adcStart(&ADCD1, NULL);
   adcSTM32EnableTSVREFE();
   palSetPadMode(GPIOC, 1, PAL_MODE_INPUT_ANALOG);      // IN11  [PC1]
   palSetPadMode(GPIOC, 2, PAL_MODE_INPUT_ANALOG);      // IN12  [PC2]
   palSetPadMode(GPIOC, 3, PAL_MODE_INPUT_ANALOG);      // IN13  [PC3]
   palSetPadMode(GPIOC, 4, PAL_MODE_INPUT_ANALOG);      // IN14  [PC4]
main.c :
int main(void)
   Init_Drivers();
   /***** Threads Creation *************************************************************************/
   chThdCreateStatic(wa_OSRunning, sizeof(wa_OSRunning), NORMALPRIO, Thread_OSRunning, NULL);
   chThdCreateStatic(wa_Accelerometer, sizeof(wa_Accelerometer), NORMALPRIO, Thread_Accelerometer, NULL);
   chThdCreateStatic(wa_ADC1, sizeof(wa_ADC1),  NORMALPRIO, Thread_ADC1, NULL);
For the ADC acquisition I use a thread and then the ADC callback function to handle the ADC samples (in main.c) :
static WORKING_AREA(wa_ADC1,         128);
static msg_t Thread_ADC1(void *arg)
   UNUSED(arg);
   chRegSetThreadName("ADC1");
   while (TRUE)
      chSysLockFromIsr();
      adcConvert(&ADCD1, &ADC1_grpcfg, ADC1_Samples, ADC_GRP1_BUF_DEPTH);
      chSysUnlockFromIsr();
      chprintf((BaseSequentialStream*) &SD3, "PC1 value : %d mV \r\n", ADC1_Samples[0]);
      chprintf((BaseSequentialStream*) &SD3, "PC2 value : %d mV \r\n", ADC1_Samples[1]);
      chprintf((BaseSequentialStream*) &SD3, "PC3 value : %d mV \r\n", ADC1_Samples[2]);
      chprintf((BaseSequentialStream*) &SD3, "PC4 value : %d mV \r\n", ADC1_Samples[3]);
   return 0;
   UNUSED(buffer);
   UNUSED(n);
   adcsample_t avg_PC1, avg_PC2, avg_PC3, avg_PC4;
   adcsample_t PC1_mV, PC2_mV, PC3_mV, PC4_mV;
   /* Note, only in the ADC_COMPLETE state because the ADC driver fires an   intermediate callback when the buffer is half full.*/
   if (adcp->state == ADC_COMPLETE)
                // Calculates the average values from the ADC samples
      avg_PC1 = (ADC1_Samples[0] + ADC1_Samples[4] + ADC1_Samples[8]  + ADC1_Samples[12]) / 4;      // temp sensor
      avg_PC2 = (ADC1_Samples[1] + ADC1_Samples[5] + ADC1_Samples[9]  + ADC1_Samples[13]) / 4;
      avg_PC3 = (ADC1_Samples[2] + ADC1_Samples[6] + ADC1_Samples[10] + ADC1_Samples[14]) / 4;
      avg_PC4 = (ADC1_Samples[3] + ADC1_Samples[7] + ADC1_Samples[11] + ADC1_Samples[15]) / 4;
      // Conversion in volt
      PC1_mV = (avg_PC1/4095) * 3300;
      PC2_mV = (avg_PC2/4095) * 3300;
      PC3_mV = (avg_PC3/4095) * 3300;
      PC4_mV = (avg_PC4/4095) * 3300;
      if ( (PC1_mV > 1500) || (PC2_mV > 1500) || (PC3_mV > 1500) || (PC4_mV > 1500) )
         palSetPad(GPIOD, LED_RED);
      else
         palClearPad(GPIOD, LED_RED);
Thanks in advance for your help !
Re: ADC1 configuration
I see one obvious error:
      chSysLockFromIsr();
You are not in ISR context. This makes me think that you are not running with debug options enabled or this error would have been caught. Please enable all the debug support in chconf.h and look for errors.
I recommend you read the "Kernel Concepts" chapter in the documentation, especially the parts regarding the system states and the call restrictions.
Nemesis2065
I have now corrected this :
   UNUSED(arg);
   while (TRUE)
      palClearPad(GPIOD, LED_GREEN);
      chThdSleepMilliseconds(300);
   return 0;
Is it a correct way to call the function adcconvert in a thread, and then work on the sample in the callback, or I can do it directly in the thread ?
You can do both things, use callbacks or wait adcConvert() to complete then process the data in the thread.
If you use the synchronous functions usually it is because you don't need callbacks, unless it is a circular conversion where, of course, callbacks are mandatory in order to process the conversion stream.
Nemesis2065
I have reviewed all my ADC code but it's still not working.
I have modified the Thread for the ADC and I am not using the ADC callback :
   UNUSED(arg);
   while (TRUE)
      //adcStartConversion(&ADCD1, &ADC1_grpcfg, ADC1_Samples, ADC_GRP1_BUF_DEPTH);
      g_avg_PC1 = (ADC1_Samples[0] + ADC1_Samples[4] + ADC1_Samples[8]  + ADC1_Samples[12]) / 4;
      g_avg_PC2 = (ADC1_Samples[1] + ADC1_Samples[5] + ADC1_Samples[9]  + ADC1_Samples[13]) / 4;
      g_avg_PC3 = (ADC1_Samples[2] + ADC1_Samples[6] + ADC1_Samples[10] + ADC1_Samples[14]) / 4;
      g_avg_PC4 = (ADC1_Samples[3] + ADC1_Samples[7] + ADC1_Samples[11] + ADC1_Samples[15]) / 4;
      g_PC1_mV = (g_avg_PC1/4095) * 3300;
      g_PC2_mV = (g_avg_PC2/4095) * 3300;
      g_PC3_mV = (g_avg_PC3/4095) * 3300;
      g_PC4_mV = (g_avg_PC4/4095) * 3300;
      palSetPad(GPIOD, LED_GREEN);
      chThdSleepMilliseconds(250);
   return 0;
I'm running another thread only for the chprintf function for no having problem inside the ADC function :
 static msg_t Thread_Debug_Printf(void *arg)
   UNUSED(arg);
   chRegSetThreadName("Debug_Printf");
   while (TRUE)
      if(g_EnablePrintf == TRUE)
         chprintf((BaseSequentialStream*) &SD3, "Sample[0]= %d - avg_PC1= %d - PC1_mV= %d \r\n", ADC1_Samples[0], g_avg_PC1, g_PC1_mV);
         chprintf((BaseSequentialStream*) &SD3, "Sample[1]= %d - avg_PC2= %d - PC2_mV= %d \r\n", ADC1_Samples[1], g_avg_PC2, g_PC2_mV);
         chprintf((BaseSequentialStream*) &SD3, "Sample[2]= %d - avg_PC3= %d - PC3_mV= %d \r\n", ADC1_Samples[2], g_avg_PC3, g_PC3_mV);
         chprintf((BaseSequentialStream*) &SD3, "Sample[3]= %d - avg_PC4= %d - PC4_mV= %d \r\n", ADC1_Samples[3], g_avg_PC4, g_PC4_mV);
         palSetPad(GPIOD, LED_BLUE);
         chThdSleepMilliseconds(500);
         palClearPad(GPIOD, LED_BLUE);
   return 0;
I kept the same configuration and the same init as the first post.
But I am getting this :
I really do not understand my mistake, is my configuration correct ?
Are pins configured in analog mode?
Nemesis2065
Yes, I do it during the initialization :
Try connecting your pins to VDD/GND and verify if the values are correct (~0, ~4095).
Djuro
Post by Djuro »
In these mathematical operation: g_PC1_mV = (g_avg_PC1/4095) * 3300; take care about numeric type data (int, double, long, float).
Unappropriated int,double,long value in dividend will result in lost part or full value in result.
Nemesis2065
I already tried to connect to VDD/GND but I have the same "random" values (see image)
g_PC1_mV and g_avg_PC1 are float type, so this should be ok.
