Porting chibios to Keil board STM32C
Re: Porting chibios to Keil board STM32C
tks for the link. however, I got this error and havent found the solution
Does that happens compiling one of the existing Keil examples?
If not, there are LOTS of settings to do in the project options, please examine one of the examples and make sure to make the same settings in your project.
it happens when I compile the demo. I keep all settings the same
Please restore the project files from the downloaded zip, I am unable to reproduce the problem here, also specify which demo are you trying and the ChibiOS version.
It compiles using Keil 5.0. It is possible you changed some setting, could you restore the demo from the zip file and try again?
I succeeded in compiling with uvision 5 but failed to download the program to the board. And I want to write a program to display sth on the display. Could you give me some suggestions on these concerns?
You have to setup your debugger (and flasher) in the project options, it depends on the debugger you are using.
