Building a static library
I'm trying to create a static library (*.a file) containing an entire project for the STM32F407-Discovery board. The goal is it to have a static library which can be compiled/linked with only a main.c to create a working project. However, I horribly fail at it.
What I did is taking the /demos/ARMCM4-STM32F407-DISCOVERY project and modify the Makefile. I removed main.c from the CSRC variable. Then I added the following to the very bottom of the Makefile:
chibios.a: $(OBJS)
   arm-none-eabi-ar r $@ $^
This way I could create the chibios.a library by executing
make chibios.a
To create the actual project, I added only the main.c to the CSRC variable and I also added the chibios.a library to the ULIBS variable. Then I ran the Makefile normally just by executing
make
Everything compiled and linked successfully. However, the created binary does not work at all (nothing gets executed at all).
I sadly don't know where the problem is but I am quite sure that it has something to do with how I create the static library. I don't really see through all the Makefile magic inside of /os/ports/GCC/ARMCMx/rules.mk to find out what I'm doing wrong.
I attached the .map file of the working project and the one with the library. The .map file of the library project does show some difference to the other at the start address:
startup
 *(vectors)
constructors    0x08000000        0x0
                0x08000000                PROVIDE (__init_array_start, .)
whilst the working one is
startup         0x08000000      0x188
 *(vectors)
 vectors        0x08000000      0x188 build/obj/vectors.o
                0x08000000                _vectors
However, I don't really know how to fix this.
Can anybody help?
map_files.zip
(34.81 KiB) Downloaded 737 times
Re: Building a static library
I have not tried this yet but I imagine it could be useful.
I would look into adding one more target "lib" to rules.mk, then, by giving the "make lib" command a library would be built.
This would indeed be useful as I'm in the process of writing a tutorial on how to use Em::Blocks with ChibiOS/RT (and optionally uGFX). It looks like you'd like to move away from Eclipse as well and I'm very satisfied with Em::Blocks so far.
I agree that it would be the best to add everything into the rules.mk Makefile. However, as long as I don't know what I have to put there, it is pretty hard for me. As everything links without any problems, I'm sure that I don't miss any object files. When looking at the resulting *.map file, it clearly looks like some startup issue.
Giovanni, is there some ChibiOS/RT black magic hidden inside which you never told anybody about it? :P
Abhishek
Post by Abhishek »
From what I understand ChibiOS as a whole will perhaps not be able to be linked as is because of the interrupt tables that are getting linked in as well, the application entry point is actually in vectors.c of the particular ChibiOS port (in this case under /ports/GCC/... ) and indeed if it could be done, it would also require relocation of interrupt tables as the HAL also uses ISRs and statically linking them in without the compiler being aware of it would be akin to their absence, which explains why your code doesn't execute.
Possible solutions:
  • Make the compiler aware of the ISRs and other stuff in the libchibios.a so that it can place it accordingly
  • Put the port, or ISR specific stuff with the application but statically link the other code [the kernel code that really doesn't need to be hardware specific].
  • Compile and put ChibiOS separately and expose a function pointer based API interface for the application to call ChibiOS functions and vice versa. Something like CircleOS App loader - visit stm32circle.com
  • Some more GCC and linker magic that I am not aware of.
  • Compile ChibiOS together with the application (which we are trying to avoid in the first place)
The best solution would be perhaps to build a plugin for any IDE of choice to do the hard work of copying the files and setting appropriate dependencies. Any other compiler magic might bloat the code. How much, I cannot say.
Regards
The solution is to put in the library only the generic modules. Startup files and vectors table belong to the application.
nad
Post by nad »
Is there some simple Makefile change to build a ChiBios library?
I think it would require a new ad-hoc makefile because all sources are assigned to the same variable in current makefiles.
nad
Post by nad »
Unfortunately I am not a Makefile guru.
So I used what the previous user had mentioned:
modified a Makfile in one of the demos directory
chibios.a: $(OBJS)
I will give it a try, will post here.
It works, I will add the change to 3.0 but not to 2.6.x, way too many makefiles to update.
If you want to add this to 2.6.x then you can add this to rules.mk just before the clean target (note you have to use TABS in targets, not spaces):
lib: $(OBJS) $(BUILDDIR)/lib$(PROJECT).a
$(BUILDDIR)/lib$(PROJECT).a: $(OBJS)
   @$(AR) -r $@ $^
   @echo
   @echo Done
Then add to the makefile:
AR   = $(TRGT)ar
Use with: make lib
Note that probably you will have to make 2 makefiles, one for building the lib only the second with everything else (your application).
