I have been trying to work around the EXT functions and I can't seem to find out how to trigger events from an external pin. this code allows me to do what I want but with the user button which i think is mapped on GPIOA pin 5 but the EXTConfig doesn't seem to have a place where I can specify the pin number?
Thank you
{EXT_CH_MODE_BOTH_EDGES | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOA, extcb1},
{EXT_CH_MODE_DISABLED, NULL},
change external interrupt from button to pin
Re: change external interrupt from button to pin
The pin numbers are the positions 0...15 in the array.
Thank you for the quick reply!
I'm afraid I don't follow, I don't see any arrays.
does the interrupt handler work on ports rather than pins? So if I have port A specified as I do here does that mean that I can use any pin on Port A?
Thank you
Thank you
You should read the EXTI documentation, that setting is in the first position of the array, this means bit 0 of PORTA-
This is the array, the fist 16 positions represent the bits in a port.
