Example code for reading AHRS from serial on Arduino Due
cambazz
Post by cambazz »
Hello All,
I setup the library ok, and managed to run blinkPrint example. I have a razor ahrs board, that outputs yaw, pitch and roll data from serial in binary form.
Each transmission starts with a $, 0x02 - and then ypr is written, which is a 12 byte array. So each packet is 14 bytes.
Serial.write('$');
Serial.write(0x02);
Serial.write((byte*) ypr, 12);
I need to read this data using ChibiOS on ARM platform, namely arduino due, namely read it from the serial port, and put it in some sort of globally accessible variables. Is there any example source code that I can start from on ChibiOS for reading serial? I have made a test program using the regular arduino language, so i managed to sync and parse the data, but I have ho idea how to do it on ChibiOS.
Re: Example code for reading AHRS from serial on Arduino Due
Most demos configure and open a serial driver port (named SD1, SD2 for example). You read something like this:
sdStart(&SD1, NULL);
You can read the port using sdGetTimeout() or sdReadTimeout().
This is the list of applicable functions:
 * @name    Macro Functions
 * @brief   Direct output check on a @p SerialDriver.
 * @note    This function bypasses the indirect access to the channel and
 *          checks directly the output queue. This is faster but cannot
 *          be used to check different channels implementations.
 * @deprecated
 * @api
#define sdPutWouldBlock(sdp) oqIsFullI(&(sdp)->oqueue)
 * @brief   Direct input check on a @p SerialDriver.
 *          checks directly the input queue. This is faster but cannot
 * @deprecated
 * @api
#define sdGetWouldBlock(sdp) iqIsEmptyI(&(sdp)->iqueue)
 * @brief   Direct write to a @p SerialDriver.
 *          writes directly on the output queue. This is faster but cannot
 *          be used to write to different channels implementations.
 * @see     chnPutTimeout()
 * @api
#define sdPut(sdp, b) oqPut(&(sdp)->oqueue, b)
 * @brief   Direct write to a @p SerialDriver with timeout specification.
 * @api
#define sdPutTimeout(sdp, b, t) oqPutTimeout(&(sdp)->oqueue, b, t)
 * @brief   Direct read from a @p SerialDriver.
 *          reads directly from the input queue. This is faster but cannot
 *          be used to read from different channels implementations.
 * @see     chnGetTimeout()
 * @api
#define sdGet(sdp) iqGet(&(sdp)->iqueue)
 * @brief   Direct read from a @p SerialDriver with timeout specification.
 * @api
#define sdGetTimeout(sdp, t) iqGetTimeout(&(sdp)->iqueue, t)
 * @brief   Direct blocking write to a @p SerialDriver.
 *          writes directly to the output queue. This is faster but cannot
 *          be used to write from different channels implementations.
 * @see     chnWrite()
 * @api
#define sdWrite(sdp, b, n)                                                  \
  oqWriteTimeout(&(sdp)->oqueue, b, n, TIME_INFINITE)
 * @brief   Direct blocking write to a @p SerialDriver with timeout
 *          specification.
 * @see     chnWriteTimeout()
 * @api
#define sdWriteTimeout(sdp, b, n, t)                                        \
  oqWriteTimeout(&(sdp)->oqueue, b, n, t)
 * @brief   Direct non-blocking write to a @p SerialDriver.
 * @api
#define sdAsynchronousWrite(sdp, b, n)                                      \
  oqWriteTimeout(&(sdp)->oqueue, b, n, TIME_IMMEDIATE)
 * @brief   Direct blocking read from a @p SerialDriver.
 * @see     chnRead()
 * @api
#define sdRead(sdp, b, n)                                                   \
  iqReadTimeout(&(sdp)->iqueue, b, n, TIME_INFINITE)
 * @brief   Direct blocking read from a @p SerialDriver with timeout
 *          specification.
 * @see     chnReadTimeout()
 * @api
#define sdReadTimeout(sdp, b, n, t)                                         \
  iqReadTimeout(&(sdp)->iqueue, b, n, t)
 * @brief   Direct non-blocking read from a @p SerialDriver.
 * @api
#define sdAsynchronousRead(sdp, b, n)                                       \
  iqReadTimeout(&(sdp)->iqueue, b, n, TIME_IMMEDIATE)
