Another interesting Discovery kit from ST
Jacon
Has thanked: 50 times
Been thanked: 5 times
Re: Another interesting Discovery kit from ST
Post by Jacon »
Giovanni,
In my opinion, first 3 lines of actual platform.mk should all point to /os/hal/platforms/STM32F4xx,
instead of /STM32L1xx, /STM32F4xx and /STM32, respectively ?!
Another (small) bugs:
- #define STM32_SERIAL_USE_USART6 FALSE doubled in mcuconf.h
- "thead" in 159'th line of trunk's "readme.txt" file.
Jacek
Thanks, fixed.
Jacon
Post by Jacon »
Hello Giovanni,
Another small notes from The Proof-reader :mrgreen: :
- line 22 of mcuconf.h - latest appearance od "STM32L1xx" in F4 version code,
- line 23 in both GPIO2/pal_lld.x files should have its first part looking
like this now:
* @brief STM32L1xx/STM32F2xx/STM32F4xx ...
Jacek
Badger
Post by Badger »
Finally had some time to build my STM32F405 based board. Haven't managed to get it to program using OpenOCD, but I eventually got the DFU USB interface working. The board has a 25Mhz crystal, and I've adjusted STM32_PLLM_VALUE to 25 and STM32_HSECLK to 25Mhz, but it flashes slowly. Is there anything else which controls the tick rate of chibios?
Jacon wrote:Hello Giovanni,
like this now:
Jacek
Thanks Jacek, fixed.
Badger wrote:Finally had some time to build my STM32F405 based board. Haven't managed to get it to program using OpenOCD, but I eventually got the DFU USB interface working. The board has a 25Mhz crystal, and I've adjusted STM32_PLLM_VALUE to 25 and STM32_HSECLK to 25Mhz, but it flashes slowly. Is there anything else which controls the tick rate of chibios?
The tick rate is controlled by CH_FREQUENCY in chconf.h but he flash speed is not related to the ChibiOS tick rate IMO.
Do you have one of the STM32 Discovery kits? you could use it as ST-Link and flash your board with it, it would probably be faster. Once setup into Eclipse I find it more convenient to use than OpenOCD, it requires no configurations for example. Of course it is limited to STM32.
BTW, better open new topics for this kind of posts, this one is about the STM32F4-Discovery kit, we don't have to economize space on the forum :).
Badger
Post by Badger »
Good idea on using the ST-Link, I'll try that. I had thought that this was a general STM32F4 topic but now that you mention it it doesn't seem the correct place!
