hi again,
i'm using chnWriteTimeout with all debug enabled, and problem is when it time-out it goes into kernel-panic as debug error.
I want to ignore this, as i'm using to write over USB-cdc only when it is connected, and someone can connect-disconnect the USB when it like (basically, i'm sending a stream of data as debug, and user can connet and look at that).
Obviusly if user disconnect at the right time, when theprint is going on, that timeout occurs, and subsequential kernel panic. Is tehrea way to tell chibios to consider that timeout as "normal flow" and not debug error?
chnWriteTimeout and debug
Re: chnWriteTimeout and debug
A timeout should not result in a panic, there is something else going on there.
What panic message are you getting? (inspect dbg_panic_msg)
msg = 0x8006b84 "\"chOQWriteTimeout\"()"
my call is chnWriteTimeout(&SDU1, data, size, timeout);
where data is "G:", size is 3, timeout is MS2ST(4) ot TIME_IMMEDIATE
chibi 2.6.x from git repo
The message does not look complete. Step into the function and see where it stops.
ifcame from "chDbgCheck(n > 0, "chOQWriteTimeout");" ofchqueues.c, seem like it does not like if i try to write an empty buffer
about the incomplete message i don't know what to expect, this is what eclipse + gdb + openocd say
See, the answer is right there
Panics should never be ignored.
thank you, you are helping me very much to understand chibios (and MCU).
it was a little strange that a timeout was causing a panic
