[INFO] ChibiOS 2.6->3.0 porting guide
part1zan_
Re: [INFO] ChibiOS 2.6->3.0 porting guide
Post by part1zan_ »
Well, AFAICS, it's definitely not a stack overflow. The thread for 2.x just locks everything by doing nothing in a cycle, when the thread for 3.x does something and doesn't lock anything. That's how I see it from my point of view. Also, how could that be a stack overflow if when I added a sleep function, everything began working just fine?
Are threads at the same priority level? In 3.0 round robin is exclusively cooperative, threads at same priority have to yield explicitly in order to rotate.
part1zan_
Post by part1zan_ »
Yes, they are at the same priority. But why is it working when I add the sleep function?
Because by going to sleep implicitly you yield and the next thread at the same priority goes in.
part1zan_
Post by part1zan_ »
Okay, I see. Thank you very much for the explanation.
part1zan_
Post by part1zan_ »
Is chrtclib ported to 3.0 yet? I get compiler errors at it.
The RTC driver in 3.0 is not yet complete and there will be no chrtclib.
part1zan_
Post by part1zan_ »
Aha, I see. So I'll wait for it. Thank you again for your kind replies.
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
A couple of things I've noticed while porting some 2.X code to 3.0:
1. chDebugPanic() seems to have vanished (although still referenced in a couple of macros in chcore.h). What's the OSAL equivalent?
2. The INLINE macro has gone - I note that 3.0 uses 'inline' - does this make it compiler-specific?
1) Now there are osalSysHalt() and chSysHalt(). I will fix the instances of the old function.
2) The 3.0 kernel has C99 as requirement so INLINE is no more required, "inline" is standard now.
