Hi all,
I'm trying to run ChibiOS on the Spark Core http://docs.spark.io/hardware/.
It features a STM32F103CB, so I started by using the demo in demos/ARMCM3-STM32F103 as a template and modified main.c to just blink a led in a thread.
I copied board.c, board.h and board.mk from boards/MAPLEMINI_STM32_F103 (same MCU) to boards/SPARK_STM32_F103 and disabled everything in halconf.h except for TM and PAL.
Since the Spark Core comes with a bootloader https://github.com/spark/bootloader, I modified (as stated in various posts in these forums) the linker script with the new flash starting point (0x8005000 instead of 0x8000000) and set the CORTEX_VTOR_INIT to 0x5000 in chconf.h
Sadly, I don't have a JTAG, so my only means of debugging are the three leds on the board (RGB).
At first, nothing worked and fiddling with the code I found that CORTEX_VTOR_INIT was the culprit: by setting it to 0x0000 chSysInit() is executed without errors, otherwise it hangs.
With this fix, the leds started to turn on but they were not turning off because the code was entering chThdSleepMilliseconds and never leaving. Removing the call to chThdSleepMilliseconds and replacing it with a loop "solved" the issue and the led blinked.
I changed the main thread to blink the blue led and the other thread to blink the green led (both NORMALPRIO): only the main thread was blinking. Adding a chThdYield to both threads, they started to blink blue and green alternately.
I suspected that interrupts are not served correctly, expecially the SysTick, so I tried to turn on a led in the SysTick hook...and it seems to never be called...
Any suggestion/hint/idea of what is going wrong?
Thank you.
P.S.
I'm using the gcc arm toolchain with the ChibiOS Makefile. You can find in attachment the project together with the linker script and the original linker scripts of the Spark Core firmware.
Re: ChibiOS on the Spark Core
Your guess is right, the problem is that interrupts are not being serviced. You should look at the map file and see if the vector table is located where you expect it to be.
Bootloaders usually also have other problems, they initialize hardware and do not restore a post-reset situation properly before handing control to the application, this can cause problems to device drivers which expect HW to be in a known state.
It seems like the bootloader enables the IWDG: https://github.com/spark/bootloader/blo ... ain.c#L283
This should be handled in a thread or using a GPT/VT, else you are going to keep rebooting.
Also I can see in the user app: NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x5000); (https://github.com/spark/core-firmware/ ... in.cpp#L86)
It should work using CORTEX_VTOR_INIT set at 0x8005000 in chconf.h (You need the full address, not just the offset, that's why it wouldn't work with 0x5000)
Thank you very much for your answers.
I added some led blinking to get the value of VTOR
in _port_init (chcore_v7m.c):
- before setting the VTOR to CORTEX_VTOR_INIT, the value in the register is 0x8000000
- after seetting the VTOR to CORTEX_VTOR_INIT, the value is 0x8005000
an extract of ch.map follows:
It seems correct to me...
However, with these settings, chSysInit hangs in the call to chSysEnable at
both with CORTEX_SIMPLIFIED_PRIORITY and without.
Same story with CORTEX_VTOR_INIT=0x5000.
Any ideas?
P.S.
At this point I (also
) don't understand why CORTEX_VTOR_INIT is set at 0 by default in the port. Shouldn't it be 0x8000000?
0x0000000000000400 __main_stack_size__ = 0x400
0x0000000000000400 __process_stack_size__ = 0x400
0x0000000020000000 __ram_start__ = ORIGIN (ram)
0x0000000000005000 __ram_size__ = 0x5000
0x0000000020005000 __ram_end__ = (__ram_start__ + __ram_size__)
0x0000000000000000 . = 0x0
0x0000000000000000 _text = .
startup 0x0000000008005000 0xec
*(vectors)
vectors 0x0000000008005000 0xec build/obj/vectors.o
0x0000000008005000 _vectors
constructors 0x00000000080050ec 0x0
0x00000000080050ec PROVIDE (__init_array_start, .)
*(SORT(.init_array.*))
*(.init_array)
0x00000000080050ec PROVIDE (__init_array_end, .)
destructors 0x00000000080050ec 0x0
0x00000000080050ec PROVIDE (__fini_array_start, .)
*(.fini_array)
*(SORT(.fini_array.*))
0x00000000080050ec PROVIDE (__fini_array_end, .)
.text 0x00000000080050f0 0xd8c
*(.text.startup.*)
.text.startup.main
0x00000000080050f0 0xf0 build/obj/main.o
0x00000000080050f0 main
*(.text)
*(.text.*)
.text.__late_init
0x00000000080051e0 0x10 build/obj/crt0.o
0x00000000080051e0 __late_init
.text._default_exit
0x00000000080051f0 0x10 build/obj/crt0.o
0x00000000080051f0 _default_exit
.text.ResetHandler
0x0000000008005200 0x110 build/obj/crt0.o
0x0000000008005200 ResetHandler
.text._unhandled_exception
0x0000000008005310 0x10 build/obj/vectors.o
0x0000000008005310 Vector58
0x0000000008005310 VectorE8
0x0000000008005310 Vector9C
0x0000000008005310 VectorAC
0x0000000008005310 Vector5C
0x0000000008005310 NMIVector
0x0000000008005310 Vector8C
0x0000000008005310 VectorDC
0x0000000008005310 VectorC8
0x0000000008005310 Vector94
0x0000000008005310 VectorA8
0x0000000008005310 VectorB4
0x0000000008005310 Vector74
0x0000000008005310 UsageFaultVector
0x0000000008005310 DebugMonitorVector
0x0000000008005310 Vector40
0x0000000008005310 VectorBC
0x0000000008005310 Vector64
0x0000000008005310 VectorCC
0x0000000008005310 Vector54
0x0000000008005310 Vector98
0x0000000008005310 VectorD8
0x0000000008005310 Vector24
0x0000000008005310 Vector84
0x0000000008005310 BusFaultVector
0x0000000008005310 VectorD0
0x0000000008005310 VectorE4
0x0000000008005310 VectorC0
0x0000000008005310 SVCallVector
0x0000000008005310 HardFaultVector
0x0000000008005310 VectorE0
0x0000000008005310 MemManageVector
0x0000000008005310 Vector6C
0x0000000008005310 VectorA0
0x0000000008005310 VectorC4
0x0000000008005310 Vector7C
0x0000000008005310 VectorB0
0x0000000008005310 Vector90
0x0000000008005310 Vector60
0x0000000008005310 Vector1C
0x0000000008005310 Vector48
0x0000000008005310 Vector70
0x0000000008005310 VectorD4
0x0000000008005310 Vector4C
0x0000000008005310 Vector80
0x0000000008005310 Vector68
0x0000000008005310 Vector78
0x0000000008005310 _unhandled_exception
0x0000000008005310 Vector88
0x0000000008005310 Vector50
0x0000000008005310 Vector44
0x0000000008005310 Vector28
0x0000000008005310 VectorB8
0x0000000008005310 Vector34
0x0000000008005310 VectorA4
0x0000000008005310 Vector20
.text._port_switch_from_isr
0x0000000008005320 0x20 build/obj/chcore_v7m.o
0x0000000008005320 _port_switch_from_isr
.text.PendSVVector
0x0000000008005340 0x10 build/obj/chcore_v7m.o
0x0000000008005340 PendSVVector
.text._port_init
0x0000000008005350 0x40 build/obj/chcore_v7m.o
0x0000000008005350 _port_init
.text._port_irq_epilogue
0x0000000008005390 0x70 build/obj/chcore_v7m.o
0x0000000008005390 _port_irq_epilogue
.text.SysTickVector
0x0000000008005400 0x20 build/obj/chcore_v7m.o
0x0000000008005400 SysTickVector
asm volatile ("cpsie i" : : : "memory")
Any ideas?
P.S.
It is possible that the bootloader leaves some non-served interrupts, when interrupts are enabled again it goes into the default service routine: an infinite loop.
We cannot go imagining what the bootloader could possibly do, you need debug capability and to talk with the author if possible.
Thank you very much!
The bootloader enables EXTI2, TIM1 and USB_LP_RX. The culprit was EXTI2, triggering Vector60 and hence _unhandled_exception.
Adding an ISR or disabling the IRQ solves the problem!
I finally have my leds blinking correctly
I see that the bootloader does not disable interrupts before booting so that's the source of your problems.
Maybe there's a reason behind that, because it's not something to dismiss...
