hi
I'm testing testhal, I2C example on STM32F4-Discovery.
I've noticed that in this example board.h is NONSTANDARD_STM32F4_BARTHESS1 and not ST_STM32F4_DISCOVERY.
When I've changed board.h to DISCOVERY, I2CD2 was not working. Then I realized that GPIOB_CLK_IN, GPIOB_SDA are connected to (PIN10,PIN9), while according to the datasheet it should be connected as follow: GPIOB_CLK_IN, GPIOB_SDA (PIN10,PIN11). BTW, on NONSTANDARD_STM32F4_BARTHESS1 I2CD2 are set according to the datasheet - please note.
my problem now is that I cannot change I2C speed or dutycycle: when I change default I2CConfig values: 400KHz or FAST_DUTY_CYCLE_2 I don't get any I2C output signal (I'm checking with both scope and logic analyzer).
any idea? thanks
Problem with changing I2C speed or dutycycle
Re: Problem with changing I2C speed or dutycycle
I cannot test that scenario, are you sure you are specifying valid values? there are restrictions according to the Reference Manual.
I'm using I2C no problem on a Discovery F4 with the following configuration:
static I2CConfig i2cfg1 = {
OPMODE_I2C,
100000,
STD_DUTY_CYCLE
Thanks a lot for your quick reply...
from any reason this is the only configuration that is working for me:
any chnge in speed or dutycycle is not working. same resaults on I2CD1 or I2CD2...
while testing I2C with my own code, without ChibiOs I'm getting 100KHz I2C.
static const I2CConfig i2cfg2 = {
OPMODE_I2C,
400000,
FAST_DUTY_CYCLE_2,
};any chnge in speed or dutycycle is not working. same resaults on I2CD1 or I2CD2...
hi,
I2C I/O settings is as follow:
After some more speed & duty-cycle combination checking, the followings are working:
400kKHz+FAST_DUTY_CYCLE_2, 100KHz+STD_DUTY_CYCLE - WORKING
400kKHz+STD_DUTY_CYCLE, 100KHz+FAST_DUTY_CYCLE_2 - NOT WORKING
For me it's OK now, but it would be nice to know if others see the same results and to understand why.
Thanks for the help!
palSetPadMode(GPIOB, 10, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN); /* SCL */
palSetPadMode(GPIOB, 11, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN); /* SDA */
