Possible ChibiOS application in project
ddichev
Post by ddichev »
Sorry if I am posting in the wrong section. I am planning to build a quadcopter, and I have decided to power it with Raspberry Pi. My idea is to avoid using a separate board for the flight control and interface it with the Pi, and instead rely on RasPi for the control - by wiring it to some sensors and ESCs and programming the flight control - and communicating to it over wifi (with a dongle). I researched it and it has been done with an ordinary linux driven Pi, apparently it was accurate enough for the practical purpose of flying the quadcopter, but I have an additional plan - I want to have a usb webcam on it, and broadcast video from it (most likely over http). I am pretty certain that the Pi won't be able to handle both properly with an ordinary raspbian linux as I was initially planning, so I started thinking about a real time OS. The reasons being, it will surely improve the quality of the control, and I suspect I will have easier time preventing the video broadcast from using resources at the expense of the flight control.
So, my actual question, since I have zero experience with RTOS, do you think the ChibiOS (and RTOS in general) and the possible time and effort I will invest in learning it are the right choice here?
Thanks in advance!
Re: Possible ChibiOS application in project
There are several quad projects using ChibiOS, apparently they seem to think that an RTOS is a good idea.
