i want to use adc hal in dual mode triggered by timer 1 ccr4. The timer feeds the pulses over TRGO and TRGO2 signals.
my ADCs 1_2 and 3_4 should both trigger on this signal. On both adcs i use 4 channels 2 for each HW ADC, and 8 Smaples / i also tried 32 samples.
But my application runs endless ly through the DMA ISR. any one an idea what is set up wrong?
ADC Config
_adcConvGrp1_2({
TRUE, /* circular mode */
U8_NBR_OF_CHANNELS,
NULL,
NULL,
* external trigger from TRGO2 of TIM1 on rising edge
ADC_CFGR_EXTSEL_SRC(10) | ADC_CFGR_EXTEN_RISING, /* CFGR */
ADC_TR(0, 4095), /* TR1 */
ADC_CCR_DUAL(1), /* CCR */
{ /* SMPR[2] */
* 20 ADC Cycles Conversion time with 7.5 clocks sample time to get a litle
* extra filtering, OPAMP1 as Input
ADC_SMPR1_SMP_AN2(ADC_SMPR_SMP_7P5),
0
{ /* Current Phase A */ /* SQR[4] */
ADC_SQR1_SQ1_N(ADC_CHANNEL_IN2)| ADC_SQR1_SQ2_N(ADC_CHANNEL_IN2),
0,
0,
0
* extra filtering, OPAMP2 as Input
{ /* SSMPR[2] */
ADC_SMPR1_SMP_AN7(ADC_SMPR_SMP_7P5),
0
{ /* DC Bus Voltage */ /* SSQR[4] */
ADC_SQR1_SQ1_N(ADC_CHANNEL_IN7) | ADC_SQR1_SQ2_N(ADC_CHANNEL_IN7),
0,
0,
0
_adcConvGrp3_4({
U8_NBR_OF_CHANNELS,
NULL,
NULL,
{ /* SMPR[2] */
0,
ADC_SMPR2_SMP_AN12(ADC_SMPR_SMP_7P5)
{ /* Current Phase C */ /* SQR[4] */
ADC_SQR1_SQ1_N(ADC_CHANNEL_IN12) | ADC_SQR1_SQ2_N(ADC_CHANNEL_IN12),
0,
0,
0
{ /* SSMPR[2] */
ADC_SMPR1_SMP_AN3(ADC_SMPR_SMP_7P5),
0
{ /* External Setpoint */ /* SSQR[4] */
ADC_SQR1_SQ1_N(ADC_CHANNEL_IN3) | ADC_SQR1_SQ2_N(ADC_CHANNEL_IN3),
0,
0,
0
start code for adc
* Activates the ADC1 driver and the temperature sensor.
adcStart(&ADCD1, NULL);
adcStart(&ADCD3, NULL);
* Starts an ADC continuous conversion.
adcStartConversion(&ADCD1, &_adcConvGrp1_2, (adcsample_t*)_samples1_2, U8_SAMPLES_PER_CHANNEL);
adcStartConversion(&ADCD3, &_adcConvGrp3_4, (adcsample_t*)_samples3_4, U8_SAMPLES_PER_CHANNEL);
Greetings
Tec
