Tick-less mode support for NilRTOS
Discussions and support about ChibiOS/NIL, the almost nil RTOS.
saraben
Re: Tick-less mode support for NilRTOS
Post by saraben »
Please refer to
viewtopic.php?f=2&t=1852&p=15327#p15327
for an explanation of the last post.
saraben
colin
Post by colin »
Interesting. So is it a bug in the Nil code? Did you fix it by adding a cast?
Apparently is a Nil bug when using 16 bits counters, I haven't look into it yet.
saraben
Post by saraben »
Giovanni,
Should I raise a bug for this 16 bit counter issue seeing V3 has gone to trunk?
Regards
Saraben
Good idea, now Nil is "official".
I committed a tentative fix along the lines of what you suggested.
Marco
Has thanked: 4 times
Been thanked: 11 times
Post by Marco »
Hello Giovanni,
On the first page of this thread you mentioned the following about the requirement of the timer for tickless mode:
Giovanni wrote:It is required a 16/32 bits up-counter with a comparator register. A down counter could be used too with extra math.
What extra math is exactly needed to use a down counter for the tickless mode instead of an up counter?
Marco
You have to make it appear as an increment counter so mostly subtractions.
