ctxp corrupted in _port_irq_epilogue
Re: ctxp corrupted in _port_irq_epilogue
Can you submit a patch? or just post on the forum the modified code. I need to modify the test application to trigger the problem also.
jbrandmeyer_bwp
Post by jbrandmeyer_bwp »
Change to the context switching code:
Index: chcore_v7m.c
--- chcore_v7m.c   (revision 670)
+++ chcore_v7m.c   (working copy)
@@ -166,6 +166,7 @@
        populate it fully.*/
     ctxp--;
     ctxp->xpsr = (regarm_t)0x01000000;
+    ctxp->fpscr = (regarm_t)SCB_FPDSCR;
     asm volatile ("msr     PSP, %0" : : "r" (ctxp) : "memory");
     /* The exit sequence is different depending on if a preemption is
@@ -249,6 +250,8 @@
 void _port_thread_start(void) {
   chSysUnlock();
+  // TODO: LTO doesn't understand that this code invokes chThdExit().
+  // chThdExit() needs to be marked "used"
   asm volatile ("mov     r0, r5                                 \n\t"
                 "blx     r4                                     \n\t"
                 "bl      chThdExit");
A snippet that enables FPU faults:
#include <ch.h>
#include <hal.h>
#include <stm32f4xx.h>
static void __attribute__((constructor))
configure_fpu_exceptions(void)
   // Enable the FPU_IRQHandler
   nvicEnableVector(FPU_IRQn, 1);
CH_IRQ_HANDLER(FPU_IRQHandler)
   // Force a hard reset on FPU exceptions
    NVIC_SystemReset();
Thanks for the patch, the LTO issue has been addressed in 3.0, the whole thing has been moved in a plain assembler module.
I committed the changes in both 2.6.x and 3.0.0, the test application has been updated as well and is able to detect the problem. 2.6.6 will probably be released next week.
Marked as bug #533.
Thank you for the patch and analysis of the problem.
