asynchronous usb communication
hi, i am using usb shell implementation to get some string from board over usb. i would using asynchronous transfer from board to pc over usb because i do not want an excessive communication overhead. How can i do it?
Re: asynchronous usb communication
The SERIAL_USB driver used by the shell demo includes asynchronous read and write functions as well synchronous ones. Its interface is exactly the same of a normal serial driver.
what is demo shell project so i can see. Thanks
I'm seeing that to write is performed on a usb chprintf().
how can I distinguish from synchronous to asynchronous?
Pask wrote:i am using usb shell implementation to get some string from board over usb
This is the shell demo.
Pask wrote:how can I distinguish from synchronous to asynchronous?
I/O functions with TIME_IMMEDIATE as timeout parameter are asynchronous.
but if I set time_immediate the operation stops immediately so the data when they are sent?
The data is sent asynchronously like you asked.
BTW, there is no performance to be gained.
ok, but if i want to replace a shell command function with an asynchronous version of it how i can?
for example i have the following code:
can i replace BaseSequentialStream with BaseChannel type as required from chnWriteTimeout?
So i replace chprintf with chnWriteTimeout and that's it?
static const ShellCommand commands[] = {
{"mem", cmd_mem},
{"threads", cmd_threads},
{"test", cmd_test},
{"write", cmd_write},
{NULL, NULL}
static void cmd_mem(BaseSequentialStream *chp, int argc, char *argv[]) {
size_t n, size;
(void)argv;
if (argc > 0) {
chprintf(chp, "Usage: mem\r\n");
return;
n = chHeapStatus(NULL, &size);
chprintf(chp, "core free memory : %u bytes\r\n", chCoreStatus());
chprintf(chp, "heap fragments : %u\r\n", n);
chprintf(chp, "heap free total : %u bytes\r\n", size);
I don't understand what you are trying to do, probably we give a different meaning to the term.
