Like in a title. I simply want to measure voltage from ADC1 IN5 - PA5.
I want to measure it constantly in my thread. If it hits some value I'll have to set PAD to 1 or 0 but this is not a problem. A problem is that I don't have any measurement results.
I looked into ADC driver note + read examples. I don't have any idea what I'm doing wrong but I constantly get a 0 in my samples.
Can you help me? I think that I'm not understanding correctly configuration structure an here is a problem.
My code:
ChibiOS/RT - Copyright (C) 2006-2013 Giovanni Di Sirio
#include "ch.h"
#include "hal.h"
#include "halconf.h"
#include "pwm.h"
#include "pal.h"
#include "pwm_lld.h"
#include "pal_lld.h"
#include "hd44780.h"
#include "display.h"
//defines for ADC
//number of channels //
#define ADC_GRP1_NUM_CHANNELS 1
//depth of conversion buffer//
#define ADC_GRP1_BUF_DEPTH 1
// clock variables
uint16_t s1;
uint16_t s2;
uint16_t m1;
uint16_t m2;
uint16_t h1;
uint16_t h2;
// ADC measurement variables
double soil_voltage;
uint16_t voltage_buffer;
uint16_t sample[1] = {0};
// ADC samples buffer.
static adcsample_t samples[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
TRUE,
ADC_GRP1_NUM_CHANNELS,
NULL,
NULL,
/* HW dependent part. */
0, // cr1
ADC_CR2_SWSTART, // cr2
0,
ADC_SMPR1_SMP_AN10(ADC_SAMPLE_41P5),
ADC_SQR1_NUM_CH(ADC_GRP1_NUM_CHANNELS),
0,
ADC_SQR3_SQ2_N(ADC_CHANNEL_IN5)
// Voltage measure
static WORKING_AREA(waPomiar, 256);
static msg_t Pomiar(void *arg) {
adcStartConversion(&ADCD1, &adcgrpcfg, samples, ADC_GRP1_BUF_DEPTH);
chThdSleepMilliseconds(2);
voltage_buffer = *samples;
/* PWM */
static PWMConfig pwmcfg = {
10000, /* 10Khz PWM clock frequency */
10000, /* PWM period 1 second */
NULL, /* No callback */
/* Only channel 1 enabled */
{PWM_OUTPUT_ACTIVE_HIGH | PWM_COMPLEMENTARY_OUTPUT_ACTIVE_HIGH, NULL},
{PWM_OUTPUT_DISABLED, NULL},
0,
0,
#if STM32_PWM_USE_ADVANCED
0
* clock thread
(void)arg;
chRegSetThreadName("clock");
while (TRUE) {
for(h1=0;h1<3;h1++)
for(h2=0;h1<5;h2++)
for(m1=0;m1<6;m1++)
for(m2=0;m2<10;m2++)
for(s1=0;s1<6;s1++)
for(s2=0;s2<10;s2++)
chThdSleepMilliseconds(1000);
return 0;
int main(void)
/* Enables PWM output (of TIM1, channel 1) on LED connected to PA8 */
palSetPadMode(GPIOA, 8, PAL_MODE_STM32_ALTERNATE_PUSHPULL);
/* Enables PWM output (of TIM1, channel 1N) on LED connected to PB13 */
palSetPadMode(GPIOB, 13, PAL_MODE_STM32_ALTERNATE_PUSHPULL);
pwmStart(&PWMD1, &pwmcfg);
pwmEnableChannel(&PWMD1, 0, 5000);
* Initializes the ADC driver 1 and enable the voltage probe
* The pin 5 on the port PA is programmed as analog input.*/
adcStart(&ADCD1, NULL);
/* INTRO */
LCD_Initialize();
disp_intro();
while (TRUE) {
Thread *tp = chThdCreateStatic(waPomiar, sizeof(waPomiar), NORMALPRIO, Pomiar, NULL);
chThdWait(tp);
//scale for mV
soil_voltage = ((double)voltage_buffer) *(3000.0/4095.0);
disp_time();
disp_measure();
Thanks for help!
Regards
Matthew
