FATS f_getfree 0 clusters
fastlink30
Post by fastlink30 »
stm32f4 discovery , chibios 2.6.6, fatfs 0,9 patched, ugfx
installed fatfs, seems all correct, i try the routine cmd_sdiotest() , under \testhal\STM32F4xx\SDC\
all is done successfully until arrive to f_getfree(), here the number of resulting cluster is everytime 0
i have changed the parameter of routine, becouse if i use &fsp as last parameter the returning parameter err is not FR_OK.
to have FR_OK i change to &SDC_FS, and no error.
err = f_getfree("/", &clusters, &SDC_FS);
what can be? communication is ok, sd card is 8mb, with only 1 partition of 680mb fat16 (tryed also with fat32)
tryed also with another sd card, same results.
tryed to pass parameter for path as "/", "0:", "1:"
one things, when i compile i get this warning:
warning: passing argument 3 of 'f_getfree' from incompatible pointer type [enabled by default]
note: expected 'struct FATFS **' but argument is of type 'struct FATFS *'
what is the correct mode to pass this argument (from static struct FATFS)?
thanks
Re: FATS f_getfree 0 clusters
The warning is definitely meaningful, apparently you have to pass a pointer to a pointer to that structure, it is like the function returns a pointer to a structure allocated internally.
fastlink30
i try with (like in the demos)
FATFS *fs;
.... , &fs);
but is not ok.
so all the demos are wrong?
No, those used to work, there must be something else.
fastlink30
at the moment i do:
FATFS *fs2;
FATFS **fsp;
fs2=(FATFS *)&SDC_FS;
*fsp=fs2;
chprintf(chp, "Mount filesystem... ");
chThdSleepMilliseconds(100);
err = f_getfree("/", &clusters, fsp);
ok, brutal, but like this seems correct, inside f_getfree() is called check_fs() wich return 2 (record signature not found)=> FR_NO_FILESYSYEM
... ach!
fastlink30
i forgot to say that i use usart6 and pins are connected like this:
DISCOVERY MMC
C6 D0
D2 CMD
C12 CLK
pins are configurate as alternative 12
if i look the fatfs source, he set the card as 4 bit bus, so i tried also with 4bit configuration
DISCOVERY MMC
C9 D1
C10 D2
C11 D3
like this, the test routine stop on first test, if i switch C6 to C8, can't connect to card.
i'm disoriented, with fatfs MUST be 4 bit bus? if yes, what are the correct pins to use with usart6?
at the moment there are active only usb1/shell, all the other things are disabled
Jeroen3
Post by Jeroen3 »
FATFS* fs;
f_getfree("0:", &freeClusters, &fs);
Works fine here. But, you'd need to call sdcStart, sdcConnect and f_mount (successfully) before f_getfree works.
You say you have an 8mb card, don't you mean 8 GB? If so, you're doing undefined stuff because the maximum size is 4 GB. Make sure your files stay below that boundary.
Why are you using an uart? Typically you'd use an SDIO or SPI to communicate with an SD card.
You haven't disabled _FS_NOFSINFO in the conf file, did you?
fastlink30
yes, i write wrong, 8gb is correct, but i have resized partition to 680mb (is the only partition, signed as active, no logical partition, fat32)
i write also usart, but is serial6, mistake, also serial must be defined becouse SDIO need it for functioning.
i not have _FS_NOFSINFO directive, is not included on the ffconf.h with the 0.9 patched shipped with chibios, i think is shipped with uGFX version of fatfs
at the moment i use fatfs from chibios to be sure all is working good, after i change to uGFX fatfs version.
i looked signal with oscilloscope, and i not see signal on d0-d3, but if i put probe on clk line, i can see signal on it, and can see if the sdcard is connected,
if i leave the probe from clk i can't connect to sd-card.
but i not understand, all the signal are with pull-up resistor. can be a problem the lenght of the cable? (sd-card <-> discovery) are only 10cm not much
thank you , you give me some more tips to follow
Jeroen3
Post by Jeroen3 »
I've looked into Chibios used here. (2.6)
But it seems you can only use the fatfs bindings with the SDCDriver, or the MMCDriver. Not Serial, not SPI.
Typically there is no pullup on the clk line. http://i.stack.imgur.com/abV6X.jpg (the transistor is optional, to be able to turn off the card)
Also, the EMI filters in the image above are often just some low ohm resistor arrays.
I doubt you are actually initializing the card properly.
Wat are the return codes of the following init functions?
- sdcStart
- sdcConnect
- f_mount
- f_getfree
- f_open(&fil, "test.txt", FA_CREATE_ALWAYS); followed by an immediate f_close(&fil); Just to make sure you can actually USE the card.
If you want, you can update fatfs to R0.10b without problems. The bindings do not require functional rework, only the type of one of the arguments require a touch. The warnings will tell you.
fastlink30
maybe i found something, before i have connection problem to sdcard, and many times on first try, fail
    chprintf(chp, "Trying to connect SDIO... ");
    if (!sdcConnect(&SDCD1))
        chprintf(chp, "OK\r\n");
so, i decided to put on loop this routine:
    int trycnt=1;
    while (1)
            chprintf(chp, "OK %d\r\n",trycnt);
            break;
        trycnt++;
[end]
and i get many different values for cnt (from 3 to 9, normally), so i change the code:
    //chprintf(chp, "Trying to connect SDIO... ");
    int trycnt=1;
    while (1)
            //chprintf(chp, "OK %d\r\n",trycnt);
            break;
        trycnt++;
[end]
and unexpectedly everytime is 1 (correct!), so at this point i can presume that is 'bug' of usb routine (i use CDC) or i not know something to use usb with sdio?
on the examples code is mixed sdio with usb, so i think there are something different to consider.
also on terminal program i not see the string 'OK .....' when card is connected, but breakpoint already arrived to [end] (if the first chprintf is without //)
