Hello everyone,
I need help to generate an interrupt from RTC every second on a board using STM32F4xx. I tried several alternatives, and have failed to make it work, does anyone could help me with an example?
Pinnchus
STM32F4 RTC interrupt every second
Re: STM32F4 RTC interrupt every second
Must it be necessarily from the RTC? you can use a virtual timer for that. Note that RTC interrupts are routed through EXTI on the F4, you need to use the EXT driver for that (see the EXT demo).
Must it be necessarily from the RTC? you could use a virtual timer for periodic interrupts.
About the RTC, its interrupts are routed through EXTI on the F4, you need to use the EXT driver for that (see the EXT demo). The EXT driver invokes a callback when an event is registered on one of its inputs.
Giovanni, Thanks for your fast answer.
Follow the example i did this add to the code (at following) and put the in the main() rutine. But does not work, am I doing somthing wrong?
Thanks for you help,
Pinnchus
extStart(&EXTD1, &extcfg);Thanks for you help,
Pinnchus
{EXT_CH_MODE_DISABLED, NULL},
{EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART | 22, extcb1}
static void extcb1(EXTDriver *extp, expchannel_t channel) {
(void)extp;
(void)channel;
chSysLockFromIsr();
OneHz();
chSysUnlockFromIsr();
}Re: STM32F4 RTC interrupt every second
Thanks....
Solved using this code as example:
https://github.com/Tecnologic/ThunderCryer/blob/master/Clock/CRTCHandler.cpp
Regards,
Pinnchus
Regards,
Pinnchus
phoenix2000
- Has thanked: 4 times
Hi Giovanni
I want to show the clock and my board is stm32f429i discovery.
Is it better to use a virtual timer and in its body read time and date of rtc instead of setting up an interrupt of rtc?
PS: As much as I understand from the datasheet for doing this, the best interrupt is wakeup interrupt which we can get interrupt in every second forever.
You may use a virtual timer or a dedicated thread for this kind of things, no need to use interrupts at all.
