STM32F4-Discovery / IAR 6.30
derspeck84
Post by derspeck84 »
Dear Folks,
I have several Problem getting Chibios running on a STM32F4-Discovery Board with IAR Workbench.
The Problem already exists in Startup just before getting to the "main" C-Routine.
When Stepping through the code, i reach the main routine without any problems, but when doing a free run, the processor ends up in a unhandled exception (undefined instruction).
With several breakpoints i found out that there must be a problem with __iar_data_init3 routine. Maybe it's a corrupted stack or something.
Has someone similar Problems when trying to run the chibios demo project with stm32f4 discovery on iar?
The stm32f4 demo project from st runs without any problems.
I hope someone can help me with this issue.
Best Regards
Pascal
Re: STM32F4-Discovery / IAR 6.30
Version 2.3.4 has been tested with IAR 6.3.0, the report is included. Which version OS are you using?
derspeck84
Thanks for your fast answer.
I used version 2.3.4 with IAR 6.3, just changed Debugger to ST-LINK, interface to SWD, activating Flashloders and getting the mentioned problems.
I don't know what I'm doing wrong!
I made a zip of my Project Directory at http://www.ewersbach.net/speck/ARMCM4-S ... COVERY.zip
Maybe someone can look at that.
The project is OK, I am able to flash and run in both release and debug modes.
My EWarm has the following version numbers (Help->About->Product Info...):
IAR Embedded Workbench for ARM: 6.21.4.2946
IAR Embedded Workbench common components: 6.3.5.2010
Is it the same?
derspeck84
No, I have the following versions:
IAR Embedded Workbench for ARM 6.30.1.3142
IAR Embedded Workbench common components 6.3.10.2075
Ath this Version Cortex M4 is supported. May the Problem be related with the FPU?
Pascal
The IAR port does not support the FPU yet, please verify if it is in the project options. I find more likely something wrong with the startup code, it is defived from the IAR 6.21 code.
HI,
I just downloaded and tested the latest version from the IAR web site:
6.30.3.3241
6.3.12.2118
The demo worked out of the box. You may consider upgrading just to rule out problems with your very specific version. Please also try to download the ChibiOS/RT 2.3.4 zip file again, there is a non null possibility that some file got corrupted somehow in your installation.
Please also verify all options regarding the ST-Link:
Driver: ST-Link
Download: Verify Downloads
Download: Use Flash Loaders
ST-Link: Reset: Normal
ST-Link: SWD
