Here is a bit more information. I noticed that all results are just below 95 Mbits/sec so I decided to calculate the theoretical maximum receive rate.
Here are the sizes of TCP over Ethernet.
Ethernet Frame Size 1518 Bytes Ethernet Preamble 8 Bytes Interframe Gap 12 Bytes Total Inter-Frame Time 1538 Bytes Ethernet Overhead 38 Bytes Ethernet Data 1500 Bytes IP Datagram Overhead 20 Bytes TCP Datagram Overhead 20 Bytes Maximum User Data per Ethernet Frame 1460 Bytes
So the data in a frame is 1460 bytes but with all overhead, 1538 bytes are sent. So the maximum rate is (100 Mbits/sec)*1460/1538 = 94.93 Mbits/sec.
This means the MAC driver must receive frames at the maximum rate. Is this possible or am I missing something?
I am new to ChibiOS, but a very experienced embedded developer; I'm intrigued by the elegant OS design but have been frustrated by the difficulty in getting the demos working and can see why the primary criticism of Chibi is the lack of documentation for beginners. I won't just whine about this, I'll be happy to contribute some documentation once I get to know the OS better.
My first goal is to get an STM32F4 Ethernet demo working. I'm trying first with the recommended Olimex STM32-E407. The adventure starts as soon as you try to build the demo. In 2.6.7, the STM32-E407 demo requires (without mention) that you need to unzip the lwip and fatfs libraries in ChibiOS/ext in order to build. More problematic for a new user is that the demo points to an older version of the board in the Makefile...I have board rev E (and so will nearly anyone else who is starting with ChibiOS). If you slog through the board posts, you'll find out that you need to change the board reference in the Makefile to OLIMEX_STM32_E407_REV_D. Unfortunately, when you build using either version of the board library and load it onto a rev E STM32-E407, the demo just hangs (no blinky LED, no virtual COM port). Note that I've built all the STM32F4-DISCOVERY demos and they worked fine (also with varying degrees of frustration trying to get them to build). I've even gotten the rather nice PPP over serial demo running on the F4 Discovery board that also uses lwIP.
The situation with the 3.0.0 development head is (understandably) worse; LwIP and FatFS are not included in the 3.0.0 directory tree at all so I copied them from the 2.6.7 /ext folder to the 3.0.0 os/ext folder, but link fails with several network functions undefined (see below).
build/obj/netif.o: In function `netif_set_up': C:\Users\dalbert\Documents\NetBeansProjects\stm32f4-chibios-lwip-pppos/lib/lwip/src/core/netif.c:468: undefined reference to `etharp_request' build/obj/netif.o: In function `netif_set_down': C:\Users\dalbert\Documents\NetBeansProjects\stm32f4-chibios-lwip-pppos/lib/lwip/src/core/netif.c:500: undefined reference to `etharp_cleanup_netif' build/obj/timers.o: In function `arp_timer': C:\Users\dalbert\Documents\NetBeansProjects\stm32f4-chibios-lwip-pppos/lib/lwip/src/core/timers.c:139: undefined reference to `etharp_tmr' build/obj/tcpip.o: In function `tcpip_thread': C:\Users\dalbert\Documents\NetBeansProjects\stm32f4-chibios-lwip-pppos/lib/lwip/src/api/tcpip.c:103: undefined reference to `ethernet_input' collect2.exe: error: ld returned 1 exit status make: *** [build/ch.elf] Error 1
Eventually, I'll figure this out, but if anyone has been successful with this (and it looks like some folks have), I'd love to know what the magic incantations were to get the LWIP-FATFS-USB demo working on a rev E STM32-E407. Thanks!
It should be sufficient to swap the board files in the makefile. Porting is covered here: http://www.chibios.org/dokuwiki/doku.ph ... port_guide The fun thing that there are complaints about the documentation being both insufficient and excessive. probably it is just insufficiently organized.
About the board, I don't have a revision E yet so that code has been placed there as contributed but I know that it has been used.
Finally about beginners, there is this new site dedicated to ChibiOS: http://www.playembedded.org hopefully it will become the resource for new users. There is also a dedicated book in the pipeline.
I found an old STM32-E407 rev B at home and the demo builds and runs correctly on it. This suggests that the problem is that the REV_D board doesn't work with rev E hardware; I'll look into this.
Please consider that this demo is tough for a new user. It would be nice if the readme stated:
- unzip ext/lwip-1.4.1_patched.zip to ext/lwip - unzip ext/fatfs-0.9_patched.zip to ext/fatfs - the STM32-E407 has multiple incompatible hardware versions and you must use the proper board version for your board. This is set in the Makefile on line 72: revs A,B,C : OLIMEX_STM32_E407 revs D: OLIMEX_STM32_E407_REV_D revs E+: not supported - the IP and MAC address are hard coded in os/various/lwip_bindings/lwip_thread.h - connect to the OTG1 USB connector to get a virtual COM port with a command line interface - when running the demo, the green LED should be blinking
It would be much nicer if the demo supported DHCP and a shell command to display the IP address (I'll work on those too). Note too that under ChibiOS 3.0.0 this demo does not build.
It is easy to activate DHCP...when I finish updating files to include the instructions I listed before, I'll send them to you and you can decide whether to include them in the next release. (or should I just use git?)
In a nutshell: In lwipopts, change LWIP_DCHP from 0 to 1 In lwipthread.c: add: #include "lwip/dhcp.h" insert after netif_set_up(&thisif);: dhcp_start(&thisif);
Attached are a small set of changes to the 2.6.7 LWIP-FATFS-USB demo that do the following:
Adds automatic DHCP support
adds "ifconfig" command to the shell to display IP and MAC addresses, link state, etc.
adds "ping" command to shell
adds comments to readme.txt to help user build the demo
I tested this with my rev B Olimex STM32-E407 and it worked nicely.
As time permits, I will figure out why the rev E hardware does not work and will submit a REV_E board file...this seems important since anyone buying a new STM32-E407 will receive rev E hardware that appears not to work with the REV_D board file.
