SD1 stupid problem
fastlink30
SD1 stupid problem
Post by fastlink30 »
i've a simple stupid problem, i can't send datas over serial (SD1)
on my custom board with stm32f103re, chibios 2.6.7
    palSetPadMode(GPIOB, 6, PAL_MODE_STM32_ALTERNATE_PUSHPULL); // tx
    palSetPadMode(GPIOB, 7, PAL_MODE_INPUT); //rx
    sdStart(&SD1, NULL);
    shellInit();
    while (TRUE)
        if (!shelltp_ser)
            shelltp_ser = shellCreate(&shell_cfg_serial, SHELL_WA_SIZE, NORMALPRIO);
            LED2_ON;
        else if (chThdTerminated(shelltp_ser))
            shelltp_ser = NULL;           /* Triggers spawning of a new shell.   */
            LED2_OFF;
sdWrite(&SD1,  (uint8_t *)"prova\r\n", 7);
no signal, if i try to toggle pins (changing SetpadMode configuration), is all ok
Re: SD1 stupid problem
Those pins can be used with USART1 only using remapping, see the RM. I remember there are also errata regarding remapping so also read that document.
fastlink30
is not the correct way to remap how i do?
errata talk about pa12, not my case
can't use PAL_MODE_ALTERNATE() with stm32f103re, right?
when book about chibios is supposed to be ready?
Remapping is not handled by the PAL driver, it is done by writing into the AFIO_MAPR, you can do that in boardInit() in your board files.
The book will be ready sometime after the official 3.0 release.
fastlink30
thank you Giovanni,
on Boardinit() i put
AFIO->MAPR |= 4;
now is functional :)
