getting Hard Fault when using fast interrupts
Re: getting Hard Fault when using fast interrupts
I tried the main() that I posted before, there is one FPU instruction in the fast handler, it worked.
Two or three version ago we found a bug regarding fast interrupts and FPU but it has been fixed, see the changelog. There is still all the discussion in the forum.
I will update the "FPU_STORM" test application with the fast IRQ and run it again, just in case.
Coreglider
Post by Coreglider »
The
#define PORT_INT_REQUIRED_STACK         128
seems to be working. Both of my boards are blinking LED's for almost an hour. I'll try to test it for a more long time, and I hope, problem will not appear again. Thank you!
It is most likely a stack overflow: keil+no optimizations+FPU = lot of stack used.
