OpenOCD
-f "board/stm32f4discovery.cfg" -c "stm32f4x.cpu configure -rtos auto"Code: Select all
Open On-Chip Debugger 0.9.0-rc1 (2015-04-24-22:05)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Info : STLINK v2 JTAG v16 API v2 SWIM v0 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 3.131969
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : accepting 'gdb' connection on tcp/3333
Info : device id = 0x10016413
Info : flash size = 1024kbytes
undefined debug reason 7 - target needs reset
Warn : No RTOS could be auto-detected!
target state: halted
xPSR: 0x01000000 pc: 0x080001c0 msp: 0x20000400
Info : Padding image section 0 with 2 bytes
Info : Padding image section 1 with 4 bytes
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x20000042 msp: 0x20000400CH_CFG_USE_REGISTRY is enabled.
ch_debug signature record is 1.
