Issues with Keil, C++ and C99 mode
RallyTronics
Post by RallyTronics »
I have been unable to get a C++ project to link properly using Keil 5.16a. I suspect it's the requirement to use C99 mode that is causing the problems. It links without errors but does not include all of the code that it should. I have the following test program:
#include "ch.hpp"
using namespace chibios_rt;
class test_thread : public BaseThread
public:
    test_thread(void)
        x = 0;
    virtual void main(void)
        while(1)
            chThdSleepMilliseconds(500);
            ++x;
    void set_x(int xx)
        x = xx;
private:
    volatile int x;
test_thread test1;
volatile int y;
int main(void)
    System::init();
    test1.set_x(5);
    test1.start(9);
    while(1)
        ++y;
test_thread functions that I don't explicitly call ( like the constructor or main ) don't get compiled in. Functions like set_x that I explicitly call work correctly.
Anyone run into this?
Re: Issues with Keil, C++ and C99 mode
Something similar happened to me using GCC a while ago, part of the class is simply discarded for some reason. I don't remember exactly what I did, something like adding a parameter to a method made the thing work but I didn't understand the root reason for the issue.
