ChibiOS - Copyright (C) 2006..2015 Giovanni Di Sirio.
This file is part of ChibiOS.
ChibiOS is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 3 of the License, or
(at your option) any later version.
ChibiOS is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
* @file ivor.s
* @brief Kernel ISRs.
* @addtogroup PPC_CORE
#if !defined(FALSE) || defined(__DOXYGEN__)
#define FALSE 0
#if !defined(TRUE) || defined(__DOXYGEN__)
#define TRUE 1
* Imports the PPC configuration headers.
#define _FROM_ASM_
#include "chconf.h"
#include "chcore.h"
#if !defined(__DOXYGEN__)
* INTC registers address.
.equ INTC_IACKR, 0xfff48010
.equ INTC_EOIR, 0xfff48018
.section .handlers, "ax"
#if PPC_SUPPORTS_DECREMENTER
* _IVOR10 handler (Book-E decrementer).
.align 4
.globl _IVOR10
.type _IVOR10, @function
_IVOR10:
/* Saving the external context (port_extctx structure).*/
stwu %sp, -80(%sp)
#if PPC_USE_VLE && PPC_SUPPORTS_VLE_MULTI
e_stmvsrrw 8(%sp) /* Saves PC, MSR. */
e_stmvsprw 16(%sp) /* Saves CR, LR, CTR, XER. */
e_stmvgprw 32(%sp) /* Saves GPR0, GPR3...GPR12. */
#else /* !(PPC_USE_VLE && PPC_SUPPORTS_VLE_MULTI) */
stw %r0, 32(%sp) /* Saves GPR0. */
mfSRR0 %r0
stw %r0, 8(%sp) /* Saves PC. */
mfSRR1 %r0
stw %r0, 12(%sp) /* Saves MSR. */
mfCR %r0
stw %r0, 16(%sp) /* Saves CR. */
mfLR %r0
stw %r0, 20(%sp) /* Saves LR. */
mfCTR %r0
stw %r0, 24(%sp) /* Saves CTR. */
mfXER %r0
stw %r0, 28(%sp) /* Saves XER. */
stw %r3, 36(%sp) /* Saves GPR3...GPR12. */
stw %r4, 40(%sp)
stw %r5, 44(%sp)
stw %r6, 48(%sp)
stw %r7, 52(%sp)
stw %r8, 56(%sp)
stw %r9, 60(%sp)
stw %r10, 64(%sp)
stw %r11, 68(%sp)
stw %r12, 72(%sp)
#endif /* !(PPC_USE_VLE && PPC_SUPPORTS_VLE_MULTI) */
/* Increasing the SPGR0 register.*/
mfspr %r0, 272
eaddi %r0, %r0, 1
mtspr 272, %r0
/* Reset DIE bit in TSR register.*/
lis %r3, 0x0800 /* DIS bit mask. */
mtspr 336, %r3 /* TSR register. */
/* Restoring pre-IRQ MSR register value.*/
mfSRR1 %r0
#if !PPC_USE_IRQ_PREEMPTION
/* No preemption, keeping EE disabled.*/
se_bclri %r0, 16 /* EE = bit 16. */
mtMSR %r0
#if CH_DBG_SYSTEM_STATE_CHECK
bl _dbg_check_enter_isr
bl _dbg_check_lock_from_isr
/* System tick handler invocation.*/
bl chSysTimerHandlerI
bl _dbg_check_unlock_from_isr
bl _dbg_check_leave_isr
#if PPC_USE_IRQ_PREEMPTION
/* Prevents preemption again.*/
wrteei 0
/* Jumps to the common IVOR epilogue code.*/
b _ivor_exit
#endif /* PPC_SUPPORTS_DECREMENTER */
* _IVOR4 handler (Book-E external interrupt).
.align 4
.globl _IVOR4
.type _IVOR4, @function
_IVOR4:
stwu %sp, -80(%sp)
mfSRR0 %r0
mfSRR1 %r0
mfCR %r0
mfLR %r0
mfCTR %r0
mfXER %r0
stw %r4, 40(%sp)
stw %r5, 44(%sp)
stw %r6, 48(%sp)
stw %r7, 52(%sp)
stw %r8, 56(%sp)
stw %r9, 60(%sp)
stw %r10, 64(%sp)
stw %r11, 68(%sp)
stw %r12, 72(%sp)
mfspr %r0, 272
eaddi %r0, %r0, 1
mtspr 272, %r0
/* Software vector address from the INTC register.*/
lis %r3, INTC_IACKR@h
ori %r3, %r3, INTC_IACKR@l /* IACKR register address. */
lwz %r3, 0(%r3) /* IACKR register value. */
lwz %r3, 0(%r3)
mtCTR %r3 /* Software handler address. */
mfSRR1 %r0
mtMSR %r0
/* Exectes the software handler.*/
bctrl
wrteei 0
/* Informs the INTC that the interrupt has been served.*/
mbar 0
lis %r3, INTC_EOIR@h
ori %r3, %r3, INTC_EOIR@l
stw %r3, 0(%r3) /* Writing any value should do. */
/* Common IVOR epilogue code, context restore.*/
.globl _ivor_exit
_ivor_exit:
/* Decreasing the SPGR0 register.*/
mfspr %r0, 272
eaddi %r0, %r0, -1
mtspr 272, %r0
#if CH_DBG_STATISTICS
bl _stats_start_measure_crit_thd
bl _dbg_check_lock
bl chSchIsPreemptionRequired
cmpli cr0, %r3, 0
beq cr0, .noresch
bl chSchDoReschedule
.noresch:
bl _stats_stop_measure_crit_thd
/* Restoring the external context.*/
e_lmvgprw 32(%sp) /* Restores GPR0, GPR3...GPR12. */
e_lmvsprw 16(%sp) /* Restores CR, LR, CTR, XER. */
e_lmvsrrw 8(%sp) /* Restores PC, MSR. */
#else /*!(PPC_USE_VLE && PPC_SUPPORTS_VLE_MULTI) */
lwz %r3, 36(%sp) /* Restores GPR3...GPR12. */
lwz %r4, 40(%sp)
lwz %r5, 44(%sp)
lwz %r6, 48(%sp)
lwz %r7, 52(%sp)
lwz %r8, 56(%sp)
lwz %r9, 60(%sp)
lwz %r10, 64(%sp)
lwz %r11, 68(%sp)
lwz %r12, 72(%sp)
lwz %r0, 8(%sp)
mtSRR0 %r0 /* Restores PC. */
lwz %r0, 12(%sp)
mtSRR1 %r0 /* Restores MSR. */
lwz %r0, 16(%sp)
mtCR %r0 /* Restores CR. */
lwz %r0, 20(%sp)
mtLR %r0 /* Restores LR. */
lwz %r0, 24(%sp)
mtCTR %r0 /* Restores CTR. */
lwz %r0, 28(%sp)
mtXER %r0 /* Restores XER. */
lwz %r0, 32(%sp) /* Restores GPR0. */
addi %sp, %sp, 80 /* Back to the previous frame. */
rfi
#endif /* !defined(__DOXYGEN__) */
If the macro CH_DBG_SYSTEM_STATE_CHECK is not "seen" by the asm module then the calls to the state checker are not compiled and this could cause that SV#8.
