my driver tested on STM32F107, but I think it is platform-independent,
since it uses the UART driver (imho finest bus timing).
the driver is configurable by next #define's
#define HAL_USE_ONEWIRE TRUE // enable driver code
#define ONEWIRE_USE_OW1 TRUE // 1wire bus #1
#define ONEWIRE_USE_OW2 FALSE // 1wire bus #2
#define ONEWIRE_USE_SEARCH FALSE // compile 1wire search algorithm
#define ONEWIRE_USE_READROM FALSE // compile owReadRom
#define ONEWIRE_USE_CRC8 TRUE // compile owCrc8
#define ONEWIRE_USE_SELECT FALSE // compile selective device support
#define ONEWIRE_USE_OVERDRIVE FALSE // compile OverDrive speed support
simple example - read TM on PB10 (there must be external pull-up)
int main(void) {
owInit();
// setup onewire bus
// set half-duplex mode & open-drain output
palSetPadMode( GPIOB, 10, PAL_MODE_STM32_ALTERNATE_OPENDRAIN );
OWD1.cfg.cr3 = USART_CR3_HDSEL;
owStart( &OWD1, &UARTD3 );
while (TRUE)
uint8_t rxbuf[8];
if( RDY_OK == owReadRom( &OWD1, rxbuf ) ) // READ_ROM command
chprintf( syscon, "rx %02X %02X %02X %02X %02X %02X %02X %02X ",
rxbuf[0], rxbuf[1], rxbuf[2], rxbuf[3], rxbuf[4], rxbuf[5], rxbuf[6], rxbuf[7] );
if( 0 == owCrc8( rxbuf, sizeof(rxbuf) ) ) chprintf( syscon, "[crc ok]" );
chprintf( syscon, "\r\n" );
chThdSleepMilliseconds(100);
more complex example - read temperature sensor
(init skipped)
while(TRUE)
if( RDY_OK == owCommand( &OWD1, 0x44, NULL, 0 ) )
chThdSleepMilliseconds( 750 );
if( RDY_OK == owCommand( &OWD1, 0xBE, rxbuf, -sizeof(rxbuf) ) ) // negative size - we will read bus
int tempr = *((uint16_t*)rxbuf) >> 2;
sprintf( txt, "T = %d.%d", tempr >> 2, (tempr & 3) * 25 );
(other code skipped)
chThdSleepSeconds( 2 );
bus scan example
(init skipped)
owSearchStart( &OWD1, 0 );
chprintf( (BaseSequentialStream *)&SD2, "Start search\r\n" );
while(TRUE)
rom_id_t dev;
result = owSearch( &OWD1, &dev );
if( RDY_OK == result )
chprintf( (BaseSequentialStream *)&SD2, "found device =" );
for( i = 0; i < 8; i++ ) chprintf( (BaseSequentialStream *)&SD2, " %02x", dev.arr[i] );
chprintf( (BaseSequentialStream *)&SD2, "\r\n" );
if( dev.arr[0] == 0x28 ) // temp sensor?
test = dev;
else
break;
if( RDY_RESET == result )
chprintf( (BaseSequentialStream *)&SD2, "bus error\r\n" );
else
owSelect( &OWD1, &test, FALSE );
result = owCommand( &OWD1, 0x44, NULL, 0, FALSE );
chprintf( (BaseSequentialStream *)&SD2, "result = %d\r\n", result );
I will be glad if someone will find it useful
