IRQ, EVENT and Srial Driver
antoniolinux
Post by antoniolinux »
hi to all
i write this code
#define EVT_UART_RX EVENT_MASK(0)
#define EVT_UART_TX EVENT_MASK(1)
#define EVT_UART_ERR EVENT_MASK(2)
 * Pointer to the UART handler thread.
static const uint8_t errore[]="Error uart";
static const uint8_t dati[]="Dati uart";
static const uint8_t letti[]="Read uart";
static const uint8_t hello[]="Hello World";
thread_t *uart_thread;
 * Red LED blinker thread, times are in milliseconds.
CH_IRQ_HANDLER(UART_RX_IRQ) {
  eventmask_t events = 0;
  uint32_t sr;
  USART_TypeDef *u=USART2;
  sr = u->SR;
  u->SR = ~sr;
  CH_IRQ_PROLOGUE();
  /* Events mask initially at zero.*/
  events = 0;
  /* If there are errors.*/
  if ((u->SR & USART_SR_ORE) != 0)
    events |= EVT_UART_ERR;
  /* If there is data available in the UART RX FIFO.*/
  if ((u->SR & (USART_SR_RXNE | USART_SR_ORE | USART_SR_NE | USART_SR_FE |
     USART_SR_PE)) != 0)
  if ((u->SR & USART_SR_TXE) != 0) {
    events |= EVT_UART_TX;
  /* Segnaling events to the thread, if any.*/
  if (events) {
    chSysLockFromISR();
    chEvtSignalI(uart_thread, events);
    chSysUnlockFromISR();
  CH_IRQ_EPILOGUE();
 static THD_WORKING_AREA(waRead1, 128);
    static THD_FUNCTION(Thread1,arg) {
  (void)arg;
    chRegSetThreadName("buffer");
    /* Thread activity.*/
    while (true) {
      /* Waiting for any event.*/
      eventmask_t evt = chEvtWaitAny(ALL_EVENTS);
      /* Serving events.*/
      if (evt & EVT_UART_ERR) {
        /* Error event.*/
        error_handler();
      if (evt & EVT_UART_RX) {
        /* Data available event.*/
        rx_handler();
      if (evt & EVT_UART_TX) {
        /* TX ready event.*/
        tx_handler();
void error_handler(){
  sdWrite(&SD2, errore, 13);
void rx_handler(){
  sdWrite(&SD2, dati, 13);
void tx_handler(){
  sdWrite(&SD2, letti, 13);
when i sand data on SD2 i don't see nothing, i dont' know where is the error
can you help me?
best regards
A.
Re: IRQ, EVENT and Srial Driver
Several problems, the main one is that you don't need to write ISRs in order to use the serial driver, the other ones are a consequence of the first one.
antoniolinux
Re: IRQ, EVENT and Serial Driver
hi rewrite all with event system but don't work......
I don't understand where is the error,
static uint8_t bufferMsg[BUFFER_SIZE];
static THD_WORKING_AREA(waRead5, 128);
static THD_FUNCTION(Thread5,arg) {
  chRegSetThreadName("th_Riempio_Buffer");
  msg_t charbuf;
  int count=0;
  uint8_t c;
  event_listener_t Uart2Data;
  eventmask_t flags;
 chEvtRegisterMask((event_source_t *)chnGetEventSource(&SD2), &Uart2Data, EVENT_MASK(1));
  while (TRUE) {
       chEvtWaitOneTimeout(EVENT_MASK(1), MS2ST(10));
       chSysLock();
       flags =chEvtGetAndClearFlags(&Uart2Data);
      chSysUnlock();
       if (flags & CHN_INPUT_AVAILABLE)
              sdWrite(&SD2,"OK\r\n",16);
int main(void) {
  sdStart(&SD2, NULL);
 chThdCreateStatic(waRead5, sizeof(waRead5),NORMALPRIO, Thread5, NULL);
  while (true) {
    if (!palReadPad(GPIOC, GPIOC_BUTTON))
      sdWrite(&SD2,"Ciao\r\n",16);
    chThdSleepMilliseconds(500);
can you help me?
You need to specify what it is supposed to do and what you get instead.
I see several strange things there:
- You wait for the event with a timeout so it exits even if the event has not occurred.
- You wait for data available then you write instead of read.
The debugger is your friend, use it.
antoniolinux
i want start a event when on SD1 arrived data, i wired the pin tx and rx for simulate the arrive data on SD1,
i write this code but when i start program the thread go in status WTANDEVT, and don't running,
event_listener_t Uart1Data;
  eventmask_t flags;
  while (TRUE) {
       chEvtWaitAll(EVENT_MASK(1));
      chSysLock();
       flags =chEvtGetAndClearFlagsI(&Uart1Data);
      chSysUnlock();
              sdWrite(&SD2,"OK\r\n",4);
main
 chEvtRegisterMask((event_source_t *)chnGetEventSource(&SD1), &Uart1Data, EVENT_MASK(1));
can you help me?
best regards
A.
antoniolinux
hi to all, i want start a event when on SD1 arrived data, i wired the pin tx and rx for simulate the arrive data on SD1,
i fix some errore in last post, and write this code:
  (void)arg;
  palSetPadMode(GPIOA, 9, PAL_MODE_ALTERNATE(7));
  palSetPadMode(GPIOA, 10, PAL_MODE_ALTERNATE(7));
  sdStart(&SD1, NULL);
  eventmask_t flags;
  while (TRUE) {
      chSysLock();
      chSysUnlock();
but now i have this error if i reset the my sT_Nucleo_L152RE and later i press the button all work well, but if i press other time i don't see nothing, i see the thread is in in status WTANDEVT, the debug don't give other problem
