Migration to eclipse Mars.1
neums
Has thanked: 10 times
Been thanked: 5 times
Post by neums »
i migrated to from Eclipse Luna to Eclipse Mars. The Compiler, Debugger etc. runs fine but i have a Problem with the indexer in eclipse.
I can open declarations in high level driver files like can.c but when i try to jump to the included low level function like can_lld_transmit() defined in can_lld.c it does not work because the indexer does not list this function.
Is there a problem with include depth or something like that? Anybody here with a hint?
Re: Migration to eclipse Mars.1
Have you tried to compile then re-index the project? indexing only works after the paths have been discovered.
neums
Post by neums »
yes, i did. I do not understand why the high Level Driver files are indexed but not the low level driver files. That does not make sence for me.
Have all paths been discovered? you can see that in project properties.
