sorry for the multipost, but I don't do much with PhpBB. mcuconf.h looks like this - I already tried switching OTG1 or OTG2 to both TRUE or FALSE, but got no change:
ChibiOS - Copyright (C) 2006..2015 Giovanni Di Sirio
#ifndef _MCUCONF_H_
#define _MCUCONF_H_
* STM32F4xx drivers configuration.
* The following settings override the default settings present in
* the various device driver implementation headers.
* Note that the settings for each driver only have effect if the whole
* driver is enabled in halconf.h.
* IRQ priorities:
* 15...0 Lowest...Highest.
* DMA priorities:
* 0...3 Lowest...Highest.
#define STM32F4xx_MCUCONF
* HAL driver system settings.
#define STM32_NO_INIT FALSE
#define STM32_HSI_ENABLED TRUE
#define STM32_LSI_ENABLED TRUE
#define STM32_HSE_ENABLED TRUE
#define STM32_LSE_ENABLED FALSE
#define STM32_CLOCK48_REQUIRED TRUE
#define STM32_SW STM32_SW_PLL
#define STM32_PLLSRC STM32_PLLSRC_HSE
#define STM32_PLLM_VALUE 8
#define STM32_PLLN_VALUE 336
#define STM32_PLLP_VALUE 2
#define STM32_PLLQ_VALUE 7
#define STM32_PPRE1 STM32_PPRE1_DIV4
#define STM32_PPRE2 STM32_PPRE2_DIV2
#define STM32_RTCSEL STM32_RTCSEL_LSI
#define STM32_RTCPRE_VALUE 8
#define STM32_MCO1SEL STM32_MCO1SEL_HSI
#define STM32_MCO1PRE STM32_MCO1PRE_DIV1
#define STM32_MCO2SEL STM32_MCO2SEL_SYSCLK
#define STM32_MCO2PRE STM32_MCO2PRE_DIV5
#define STM32_I2SSRC STM32_I2SSRC_CKIN
#define STM32_PLLI2SN_VALUE 192
#define STM32_PLLI2SR_VALUE 5
#define STM32_PVD_ENABLE FALSE
#define STM32_PLS STM32_PLS_LEV0
#define STM32_BKPRAM_ENABLE FALSE
* ADC driver system settings.
#define STM32_ADC_ADCPRE ADC_CCR_ADCPRE_DIV4
#define STM32_ADC_USE_ADC1 FALSE
#define STM32_ADC_USE_ADC2 FALSE
#define STM32_ADC_USE_ADC3 FALSE
#define STM32_ADC_ADC1_DMA_STREAM STM32_DMA_STREAM_ID(2, 4)
#define STM32_ADC_ADC2_DMA_STREAM STM32_DMA_STREAM_ID(2, 2)
#define STM32_ADC_ADC3_DMA_STREAM STM32_DMA_STREAM_ID(2, 1)
#define STM32_ADC_ADC1_DMA_PRIORITY 2
#define STM32_ADC_ADC2_DMA_PRIORITY 2
#define STM32_ADC_ADC3_DMA_PRIORITY 2
#define STM32_ADC_IRQ_PRIORITY 6
#define STM32_ADC_ADC1_DMA_IRQ_PRIORITY 6
#define STM32_ADC_ADC2_DMA_IRQ_PRIORITY 6
#define STM32_ADC_ADC3_DMA_IRQ_PRIORITY 6
* CAN driver system settings.
#define STM32_CAN_USE_CAN1 FALSE
#define STM32_CAN_USE_CAN2 FALSE
#define STM32_CAN_CAN1_IRQ_PRIORITY 11
#define STM32_CAN_CAN2_IRQ_PRIORITY 11
* DAC driver system settings.
#define STM32_DAC_DUAL_MODE FALSE
#define STM32_DAC_USE_DAC1_CH1 FALSE
#define STM32_DAC_USE_DAC1_CH2 FALSE
#define STM32_DAC_DAC1_CH1_IRQ_PRIORITY 10
#define STM32_DAC_DAC1_CH2_IRQ_PRIORITY 10
#define STM32_DAC_DAC1_CH1_DMA_PRIORITY 2
#define STM32_DAC_DAC1_CH2_DMA_PRIORITY 2
#define STM32_DAC_DAC1_CH1_DMA_STREAM STM32_DMA_STREAM_ID(1, 5)
#define STM32_DAC_DAC1_CH2_DMA_STREAM STM32_DMA_STREAM_ID(1, 6)
* EXT driver system settings.
#define STM32_EXT_EXTI0_IRQ_PRIORITY 6
#define STM32_EXT_EXTI1_IRQ_PRIORITY 6
#define STM32_EXT_EXTI2_IRQ_PRIORITY 6
#define STM32_EXT_EXTI3_IRQ_PRIORITY 6
#define STM32_EXT_EXTI4_IRQ_PRIORITY 6
#define STM32_EXT_EXTI5_9_IRQ_PRIORITY 6
#define STM32_EXT_EXTI10_15_IRQ_PRIORITY 6
#define STM32_EXT_EXTI16_IRQ_PRIORITY 6
#define STM32_EXT_EXTI17_IRQ_PRIORITY 15
#define STM32_EXT_EXTI18_IRQ_PRIORITY 6
#define STM32_EXT_EXTI19_IRQ_PRIORITY 6
#define STM32_EXT_EXTI20_IRQ_PRIORITY 6
#define STM32_EXT_EXTI21_IRQ_PRIORITY 15
#define STM32_EXT_EXTI22_IRQ_PRIORITY 15
* GPT driver system settings.
#define STM32_GPT_USE_TIM1 FALSE
#define STM32_GPT_USE_TIM2 FALSE
#define STM32_GPT_USE_TIM3 FALSE
#define STM32_GPT_USE_TIM4 FALSE
#define STM32_GPT_USE_TIM5 FALSE
#define STM32_GPT_USE_TIM6 FALSE
#define STM32_GPT_USE_TIM7 FALSE
#define STM32_GPT_USE_TIM8 FALSE
#define STM32_GPT_USE_TIM9 FALSE
#define STM32_GPT_USE_TIM11 FALSE
#define STM32_GPT_USE_TIM12 FALSE
#define STM32_GPT_USE_TIM14 FALSE
#define STM32_GPT_TIM1_IRQ_PRIORITY 7
#define STM32_GPT_TIM2_IRQ_PRIORITY 7
#define STM32_GPT_TIM3_IRQ_PRIORITY 7
#define STM32_GPT_TIM4_IRQ_PRIORITY 7
#define STM32_GPT_TIM5_IRQ_PRIORITY 7
#define STM32_GPT_TIM6_IRQ_PRIORITY 7
#define STM32_GPT_TIM7_IRQ_PRIORITY 7
#define STM32_GPT_TIM8_IRQ_PRIORITY 7
#define STM32_GPT_TIM9_IRQ_PRIORITY 7
#define STM32_GPT_TIM11_IRQ_PRIORITY 7
#define STM32_GPT_TIM12_IRQ_PRIORITY 7
#define STM32_GPT_TIM14_IRQ_PRIORITY 7
* I2C driver system settings.
#define STM32_I2C_USE_I2C1 FALSE
#define STM32_I2C_USE_I2C2 FALSE
#define STM32_I2C_USE_I2C3 FALSE
#define STM32_I2C_BUSY_TIMEOUT 50
#define STM32_I2C_I2C1_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 0)
#define STM32_I2C_I2C1_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 6)
#define STM32_I2C_I2C2_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 2)
#define STM32_I2C_I2C2_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 7)
#define STM32_I2C_I2C3_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 2)
#define STM32_I2C_I2C3_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 4)
#define STM32_I2C_I2C1_IRQ_PRIORITY 5
#define STM32_I2C_I2C2_IRQ_PRIORITY 5
#define STM32_I2C_I2C3_IRQ_PRIORITY 5
#define STM32_I2C_I2C1_DMA_PRIORITY 3
#define STM32_I2C_I2C2_DMA_PRIORITY 3
#define STM32_I2C_I2C3_DMA_PRIORITY 3
#define STM32_I2C_DMA_ERROR_HOOK(i2cp) osalSysHalt("DMA failure")
* ICU driver system settings.
#define STM32_ICU_USE_TIM1 FALSE
#define STM32_ICU_USE_TIM2 FALSE
#define STM32_ICU_USE_TIM3 FALSE
#define STM32_ICU_USE_TIM4 FALSE
#define STM32_ICU_USE_TIM5 FALSE
#define STM32_ICU_USE_TIM8 FALSE
#define STM32_ICU_USE_TIM9 FALSE
#define STM32_ICU_TIM1_IRQ_PRIORITY 7
#define STM32_ICU_TIM2_IRQ_PRIORITY 7
#define STM32_ICU_TIM3_IRQ_PRIORITY 7
#define STM32_ICU_TIM4_IRQ_PRIORITY 7
#define STM32_ICU_TIM5_IRQ_PRIORITY 7
#define STM32_ICU_TIM8_IRQ_PRIORITY 7
#define STM32_ICU_TIM9_IRQ_PRIORITY 7
* MAC driver system settings.
#define STM32_MAC_TRANSMIT_BUFFERS 2
#define STM32_MAC_RECEIVE_BUFFERS 4
#define STM32_MAC_BUFFERS_SIZE 1522
#define STM32_MAC_PHY_TIMEOUT 100
#define STM32_MAC_ETH1_CHANGE_PHY_STATE TRUE
#define STM32_MAC_ETH1_IRQ_PRIORITY 13
#define STM32_MAC_IP_CHECKSUM_OFFLOAD 0
* PWM driver system settings.
#define STM32_PWM_USE_ADVANCED FALSE
#define STM32_PWM_USE_TIM1 FALSE
#define STM32_PWM_USE_TIM2 FALSE
#define STM32_PWM_USE_TIM3 FALSE
#define STM32_PWM_USE_TIM4 FALSE
#define STM32_PWM_USE_TIM5 FALSE
#define STM32_PWM_USE_TIM8 FALSE
#define STM32_PWM_USE_TIM9 FALSE
#define STM32_PWM_TIM1_IRQ_PRIORITY 7
#define STM32_PWM_TIM2_IRQ_PRIORITY 7
#define STM32_PWM_TIM3_IRQ_PRIORITY 7
#define STM32_PWM_TIM4_IRQ_PRIORITY 7
#define STM32_PWM_TIM5_IRQ_PRIORITY 7
#define STM32_PWM_TIM8_IRQ_PRIORITY 7
#define STM32_PWM_TIM9_IRQ_PRIORITY 7
* SDC driver system settings.
#define STM32_SDC_SDIO_DMA_PRIORITY 3
#define STM32_SDC_SDIO_IRQ_PRIORITY 9
#define STM32_SDC_WRITE_TIMEOUT_MS 250
#define STM32_SDC_READ_TIMEOUT_MS 25
#define STM32_SDC_CLOCK_ACTIVATION_DELAY 10
#define STM32_SDC_SDIO_UNALIGNED_SUPPORT TRUE
#define STM32_SDC_SDIO_DMA_STREAM STM32_DMA_STREAM_ID(2, 3)
* SERIAL driver system settings.
#define STM32_SERIAL_USE_USART1 FALSE
#define STM32_SERIAL_USE_USART2 FALSE
#define STM32_SERIAL_USE_USART3 FALSE
#define STM32_SERIAL_USE_UART4 FALSE
#define STM32_SERIAL_USE_UART5 FALSE
#define STM32_SERIAL_USE_USART6 FALSE
#define STM32_SERIAL_USART1_PRIORITY 12
#define STM32_SERIAL_USART2_PRIORITY 12
#define STM32_SERIAL_USART3_PRIORITY 12
#define STM32_SERIAL_UART4_PRIORITY 12
#define STM32_SERIAL_UART5_PRIORITY 12
#define STM32_SERIAL_USART6_PRIORITY 12
* SPI driver system settings.
#define STM32_SPI_USE_SPI1 FALSE
#define STM32_SPI_USE_SPI2 FALSE
#define STM32_SPI_USE_SPI3 FALSE
#define STM32_SPI_USE_SPI4 FALSE
#define STM32_SPI_USE_SPI5 FALSE
#define STM32_SPI_USE_SPI6 FALSE
#define STM32_SPI_SPI1_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 0)
#define STM32_SPI_SPI1_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 3)
#define STM32_SPI_SPI2_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 3)
#define STM32_SPI_SPI2_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 4)
#define STM32_SPI_SPI3_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 0)
#define STM32_SPI_SPI3_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 7)
#define STM32_SPI_SPI4_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 0)
#define STM32_SPI_SPI4_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 1)
#define STM32_SPI_SPI5_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 3)
#define STM32_SPI_SPI5_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 4)
#define STM32_SPI_SPI6_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 6)
#define STM32_SPI_SPI6_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 5)
#define STM32_SPI_SPI1_DMA_PRIORITY 1
#define STM32_SPI_SPI2_DMA_PRIORITY 1
#define STM32_SPI_SPI3_DMA_PRIORITY 1
#define STM32_SPI_SPI4_DMA_PRIORITY 1
#define STM32_SPI_SPI5_DMA_PRIORITY 1
#define STM32_SPI_SPI6_DMA_PRIORITY 1
#define STM32_SPI_SPI1_IRQ_PRIORITY 10
#define STM32_SPI_SPI2_IRQ_PRIORITY 10
#define STM32_SPI_SPI3_IRQ_PRIORITY 10
#define STM32_SPI_SPI4_IRQ_PRIORITY 10
#define STM32_SPI_SPI5_IRQ_PRIORITY 10
#define STM32_SPI_SPI6_IRQ_PRIORITY 10
#define STM32_SPI_DMA_ERROR_HOOK(spip) osalSysHalt("DMA failure")
* ST driver system settings.
#define STM32_ST_IRQ_PRIORITY 8
#define STM32_ST_USE_TIMER 2
* UART driver system settings.
#define STM32_UART_USE_USART1 FALSE
#define STM32_UART_USE_USART2 FALSE
#define STM32_UART_USE_USART3 FALSE
#define STM32_UART_USE_UART4 FALSE
#define STM32_UART_USE_UART5 FALSE
#define STM32_UART_USE_USART6 FALSE
#define STM32_UART_USART1_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 5)
#define STM32_UART_USART1_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 7)
#define STM32_UART_USART2_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 5)
#define STM32_UART_USART2_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 6)
#define STM32_UART_USART3_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 1)
#define STM32_UART_USART3_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 3)
#define STM32_UART_UART4_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 2)
#define STM32_UART_UART4_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 4)
#define STM32_UART_UART5_RX_DMA_STREAM STM32_DMA_STREAM_ID(1, 0)
#define STM32_UART_UART5_TX_DMA_STREAM STM32_DMA_STREAM_ID(1, 7)
#define STM32_UART_USART6_RX_DMA_STREAM STM32_DMA_STREAM_ID(2, 2)
#define STM32_UART_USART6_TX_DMA_STREAM STM32_DMA_STREAM_ID(2, 7)
#define STM32_UART_USART1_IRQ_PRIORITY 12
#define STM32_UART_USART2_IRQ_PRIORITY 12
#define STM32_UART_USART3_IRQ_PRIORITY 12
#define STM32_UART_UART4_IRQ_PRIORITY 12
#define STM32_UART_UART5_IRQ_PRIORITY 12
#define STM32_UART_USART6_IRQ_PRIORITY 12
#define STM32_UART_USART1_DMA_PRIORITY 0
#define STM32_UART_USART2_DMA_PRIORITY 0
#define STM32_UART_USART3_DMA_PRIORITY 0
#define STM32_UART_UART4_DMA_PRIORITY 0
#define STM32_UART_UART5_DMA_PRIORITY 0
#define STM32_UART_USART6_DMA_PRIORITY 0
#define STM32_UART_DMA_ERROR_HOOK(uartp) osalSysHalt("DMA failure")
* USB driver system settings.
#define STM32_USB_USE_OTG1 FALSE
#define STM32_USB_USE_OTG2 TRUE
#define STM32_USB_OTG1_IRQ_PRIORITY 14
#define STM32_USB_OTG2_IRQ_PRIORITY 14
#define STM32_USB_OTG1_RX_FIFO_SIZE 512
#define STM32_USB_OTG2_RX_FIFO_SIZE 1024
#define STM32_USB_OTG_THREAD_PRIO LOWPRIO
#define STM32_USB_OTG_THREAD_STACK_SIZE 128
#define STM32_USB_OTGFIFO_FILL_BASEPRI 0
#endif /* _MCUCONF_H_ */
