As a result of Subversion Revision 8280, builds for the STM32F407 using GCC are excessively large.
Using the RT-STM32F407-DISCOVERY example project (unmodified) and the latest trunk code, the program compiles to 158240 bytes. By reversing the changes made to os/common/ports/ARM/ARMCMx/compilers/GCC/rules.ld in that commit the compiled size goes back down to 32144.
Similarly, for another project using a STM32F103x8 it compiles to 46698 bytes with the heap assignment linker script and 34090 bytes without. Is this expected behaviour?
On another note, the STM43F103x8 devices are not currently supported by the HAL macros. These devices are Medium Density so it works fine to use the STM32F103xB definition, but I just thought I'd let you know anyway. Not a huge priority.
GCC rules.ld heap assignment
Re: GCC rules.ld heap assignment
Compiling the demo this is what I get:
Going into details:
The code size is the same. The difference is caused by how the heap is allocated. The old method was to use all RAM not allocated, the new method is to allocate the remaining RAM for the heap into a specific ".heap" section. This means that now apparently the RAM is always all used.
text data bss dec hex filename
26716 632 130892 158240 26a20 build/ch.elf
Going into details:
Idx Name Size VMA LMA File off Algn
0 startup 000001c0 08000000 08000000 00008000 2**4
CONTENTS, ALLOC, LOAD, DATA
1 .text 0000685c 080001c0 080001c0 000081c0 2**4
CONTENTS, ALLOC, LOAD, READONLY, CODE
2 .textalign 00000004 08006a1c 08006a1c 0000ea1c 2**0
ALLOC
3 .mstack 00000400 20000000 20000000 00018000 2**0
ALLOC
4 .pstack 00000400 20000400 20000400 00018000 2**0
ALLOC
5 .data 000000b8 20000800 08006a20 00010800 2**2
6 .bss 00000ab8 200008b8 08006ad8 000108b8 2**3
ALLOC
7 .ram0 00000000 20001370 20001370 000108b8 2**2
CONTENTS
8 .ram1 00000000 20000000 20000000 000108b8 2**2
CONTENTS
9 .ram2 00000000 2001c000 2001c000 000108b8 2**2
CONTENTS
10 .ram3 00000000 00000000 00000000 000108b8 2**2
CONTENTS
11 .ram4 00000000 10000000 10000000 000108b8 2**2
CONTENTS
12 .ram5 00000000 40024000 40024000 000108b8 2**2
CONTENTS
13 .ram6 00000000 00000000 00000000 000108b8 2**2
CONTENTS
14 .ram7 00000000 00000000 00000000 000108b8 2**2
CONTENTS
15 .heap 0001ec90 20001370 20001370 00018000 2**0
ALLOC
