I'm currently using a Nucleo F411RE with a MCP23017. I have i2c on GPIOB 6,7 (SCL, SDA), a gpio interrupt off its INTA pin attached to GPIOB 4, and GPIOB 5 on its reset pin. I can do as many i2c write/reads as I want from the main() function and everything works, I press a button, it generates an interrupt, I read the MCP23017 registers and I get proper values. However, as soon as I try to do ANYTHING with i2c in a thread, it halts in i2c_lld_serve_rx_end_irq / chThdResumeI. This happens no matter what nucleo I try, I've tried a F401, a L152 and some others just to make sure it's not the F4 that's the issue. I'm using ChibiStudio, chibios 3, and I copied the Nucleo F411RE project (and edited it). I disabled all the other peripherals I don't need except I2C in both the mcuconf and halconf. I left everything else alone (and I turned on debug stuff in chconf). I also tried both STD_DUTY_CYCLE and FAST_DUTY_CYCLE_2. I have 1.5k pullups on the SDA/SCL lines.
Does it look like there's anything I'm doing wrong in my code? Anyone have any ideas?
Thanks!
Here's my stack trace:
Here's my code (I've included the entire example in case someone wants to build it with their own confs and so you can see everything I've tried to make this work):
#include <string.h>
#include "ch.h"
#include "hal.h"
#include "test.h"
static const I2CConfig i2cfg1 = {
.op_mode = OPMODE_I2C,
.clock_speed = 100000,
.duty_cycle = STD_DUTY_CYCLE,
typedef enum {
MCP23017_PIN0 = 0,
MCP23017_PIN1 = 2,
MCP23017_PIN2 = 4,
MCP23017_PIN3 = 8,
MCP23017_PIN4 = 16,
MCP23017_PIN5 = 32,
MCP23017_PIN6 = 64,
MCP23017_PIN7 = 128,
} MCP23017_Pin_t;
typedef struct {
GPIO_TypeDef *port;
uint32_t pin;
} GPIOPin_t;
typedef struct {
uint8_t address;
GPIOPin_t intPin;
uint16_t intEnabledPins; // Internal, DO NOT MESS WITH THIS!
} MCP23017_t;
typedef enum {
REG_IODIRA = 0,
REG_IODIRB,
REG_IPOLA,
REG_IPOLB,
REG_GPINTENA,
REG_GPINTENB,
REG_DEFVALA,
REG_DEFVALB,
REG_INTCONA,
REG_INTCONB,
REG_IOCONA,
REG_IOCONB,
REG_GPPUA,
REG_GPPUB,
REG_INTFA,
REG_INTFB,
REG_INTCAPA,
REG_INTCAPB,
REG_GPIOA,
REG_GPIOB,
REG_OLATA,
REG_OLATB,
} MCP23017_Registers_t;
typedef enum {
IOCON_UNIMPLEMENTED = 0,
IOCON_INTPOL = 2,
IOCON_ODR = 4,
IOCON_HAEN = 8,
IOCON_DISSLW = 16,
IOCON_SEQOP = 32,
IOCON_MIRROR = 64,
IOCON_BANK = 128,
} MCP23017_IOCON_Bits_t;
#define MCP23017_ADDRESS(chip) (0x20 | chip->address)
#define PortAByte(x) (x & 0xFF)
#define PortBByte(x) (x >> 8)
#define PortABWord(buff) (buff[0] | (buff[1] << 8))
void MCP23017_Init(MCP23017_t *chip) {
chip->intEnabledPins = 0;
void MCP23017_SetInterruptPins(MCP23017_t* chip, uint16_t pins) {
// This will write GPINTENA, B, DEFVALA, B, and INTCONA, B all at the same time because we're in SEQ mode
// We just give it the start address and it bumps the address for each successive byte
// (all of those registers are in successive address order)
// Interrupt compares on previous pin value
uint8_t data[] = { REG_GPINTENA, PortAByte(pins), PortBByte(pins), 0, 0, 0, 0 };
i2cMasterTransmitTimeout(&I2CD1, MCP23017_ADDRESS(chip), data, sizeof(data), NULL, 0, MS2ST(1000));
chip->intEnabledPins = pins;
void MCP23017_MirrorInterrupt(MCP23017_t* chip, uint8_t mirror) {
// First, read IOCON
uint8_t getIOCON[] = { REG_IOCONA };
uint8_t ioCONValue[] = { 0, 0 }; // Fucking lame i2c bug requires minimum 2 byte read
i2cMasterTransmitTimeout(&I2CD1, MCP23017_ADDRESS(chip), getIOCON, sizeof(getIOCON), ioCONValue, sizeof(ioCONValue), MS2ST(1000));
// Now munge the MIRROR bit and write IOCON back out
uint8_t setIOCON[] = { REG_IOCONA, 0 };
if (mirror)
setIOCON[1] = *ioCONValue | IOCON_MIRROR;
else
setIOCON[1] = *ioCONValue & ~IOCON_MIRROR;
i2cMasterTransmitTimeout(&I2CD1, MCP23017_ADDRESS(chip), setIOCON, sizeof(setIOCON), NULL, 0, MS2ST(1000));
void MCP23017_SetPullups(MCP23017_t* chip, uint16_t pins) {
uint8_t data[] = { REG_GPPUA, PortAByte(pins), PortBByte(pins) };
/// @brief gets the interrupt capture values for pins with interrupts enabled, and gpio values for the ones that aren't
uint16_t MCP23017_GetPinValues(MCP23017_t* chip) {
uint16_t pinValues = 0;
if (chip->intEnabledPins != 0) {
uint8_t getIntPins[] = { REG_INTCAPA };
uint8_t intPins[2];
i2cMasterTransmitTimeout(&I2CD1, MCP23017_ADDRESS(chip), getIntPins, sizeof(getIntPins), intPins, sizeof(intPins), MS2ST(1000));
pinValues = PortABWord(intPins);
uint8_t getGPIOPins[] = { REG_GPIOA };
uint8_t gpioPins[2];
i2cMasterTransmitTimeout(&I2CD1, MCP23017_ADDRESS(chip), getGPIOPins, sizeof(getGPIOPins), gpioPins, sizeof(gpioPins), MS2ST(1000));
uint16_t gpioValue = PortABWord(gpioPins);
pinValues |= (gpioValue & ~chip->intEnabledPins); // Don't let current gpio values overwrite the intcap values
return pinValues;
void MCP23017_GetRegisters(MCP23017_t* chip, uint8_t *registers) {
uint8_t getRegisters[] = { REG_IODIRA };
i2cMasterTransmitTimeout(&I2CD1, MCP23017_ADDRESS(chip), getRegisters, sizeof(getRegisters), registers, 22, MS2ST(1000));
static uint8_t pinInterrupted = 0;
// Tried this too with no luck
//CH_IRQ_HANDLER(EXTI4_Handler) {
// CH_IRQ_PROLOGUE();
//// chSysLockFromISR();
// pinInterrupted = 1;
//// chSysUnlockFromISR();
// CH_IRQ_EPILOGUE();
static thread_reference_t thread2Wakeup = NULL;
static void keypadInterrupt(EXTDriver *extp, expchannel_t channel)
(void)extp;
(void)channel;
chSysLockFromISR();
chThdResumeI(&thread2Wakeup, (msg_t)0x1337);
{EXT_CH_MODE_DISABLED, NULL},
{EXT_CH_MODE_FALLING_EDGE | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOB, keypadInterrupt},
typedef struct {
uint16_t pins;
uint32_t time;
} Press_t;
static MCP23017_t keypadNButtons = {
.address = 0,
.intPin = {
GPIOB,
4 },
(void)arg;
static Press_t pinValuesOverTime[16];
memset(pinValuesOverTime, 0, sizeof(pinValuesOverTime));
uint16_t pinValuesIndex = 0;
while (true) {
chSysLock();
msg_t msg = chThdSuspendS(&thread2Wakeup);
chSysUnlock();
// if (pinInterrupted) {
chThdSleepMilliseconds(20);
// pinInterrupted = 0;
i2cAcquireBus(&I2CD1);
// i2cStart(&I2CD1, &i2cfg1); // this didn't help either
pinValuesOverTime[pinValuesIndex].pins = MCP23017_GetPinValues(&keypadNButtons);
// i2cStop(&I2CD1);
i2cReleaseBus(&I2CD1);
pinValuesOverTime[pinValuesIndex].time = chVTGetSystemTime();
pinValuesIndex++;
pinValuesIndex %= sizeof(pinValuesOverTime);
int main(void) {
palSetPadMode(GPIOB, 5, PAL_MODE_OUTPUT_PUSHPULL | PAL_STM32_OSPEED_LOWEST);
palSetPadMode(GPIOB, 6, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN);
palSetPadMode(GPIOB, 7, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN);
osalSysPolledDelayX( MS2ST(100) );
// chThdSleepMilliseconds(100);
palClearPad(GPIOB, 5);
palSetPad(GPIOB, 5);
uint8_t initRegisters[22];
MCP23017_GetRegisters(&keypadNButtons, initRegisters);
MCP23017_Init(&keypadNButtons);
MCP23017_SetPullups(&keypadNButtons, 0xFFFF);
MCP23017_SetInterruptPins(&keypadNButtons, 0xFFFF);
MCP23017_MirrorInterrupt(&keypadNButtons, 1);
uint8_t registers[22];
MCP23017_GetRegisters(&keypadNButtons, registers);
// i2cStop(&I2CD1);
extStart(&EXTD1, &extcfg);
// NVIC_EnableIRQ(EXTI4_IRQn);
* Creates the blinker thread.
* sleeping in a loop and check the button state.
while (true) {
// So, if I use my variable setting method and do this NOT in a thread, it works. Neither variable setting or suspending/resuming works in a thread
// osalSysPolledDelayX( MS2ST(20) ); // Debounce?
// pinValuesOverTime[pinValuesIndex].pins = MCP23017_GetPinValues(&keypadNButtons);
// pinValuesOverTime[pinValuesIndex].time = chVTGetSystemTime();
// pinValuesIndex++;
chThdSleepMilliseconds(50000);
