Is anyone using Chibi on the nRF51?
Moderator: utzig
Just wondered - has anyone got this working? Using the SoftDevice?
Re: Is anyone using Chibi on the nRF51?
No idea about the capabilities of the nRF51 port, but there is one in the contrib tree (I think by utzig, barthess and doceme).
- Has thanked: 1146 times
- Been thanked: 960 times
It is a new port, Fabio Utzig is handling it, just wait for him to comment.
I've ported Chibios about 2 years ago on the nrf51. At this time I've used last revison of Chibios (2.6.5). Chibios is running perfectly with different drivers like uart, spi, i2c, timers.... I've started to integrate the softdevice one year ago but it's not working correctly. I don't know why, but IRQ are not enabled when I call specific softdevice functions but are enabled when normal functions
see my thread on the nordic semi forum:
https://devzone.nordicsemi.com/question ... interrupt/
I've put on GITHUB my port, all details of the issue are in "main.c" and the readme file:
https://github.com/bubune/Chibios_NRF51_SD
If someone can helping me, will be nice.
Bruno
Bruno
just to let you know the issue is fixed and the port look stable. I run the demo for 30min with a ANT+ HRM belt without any issue
Let me know if you find a problem.
I hope it will be usefull for someone.
It's easy to port and use the nordicsemi bluetooth stack S130 and other...
Regards,
Bruno
Regards,
Bruno
Hi Bruno,
Good job and very interesting, do you thing it will also support BLE instead of ANT+ and should also support other soft devices like SD110?
Will try to follow your steps for those cases, it would be quite neat to get ChibiOS running on it.
Regards,
Raul
Regards,
Raul
Hi Raul,
I'm currently working on a improved demo by using SD310 to use both stack (ANT and BLE). Insteand to send data over UART, in the new demo, the UART BLE profile will be use. From that, it should be easy to use other SD from Nordic.
I will post news here when it will be done. However, I can not tell you when it will be done. I'm very busy at home, and I've urgent task to be done before.
Bruno
Bruno
Users browsing this forum: No registered users and 100 guests
