Accessing DMA NDTR for STM32F4
samtatasurya
Post by samtatasurya »
Hi everyone,
I'm currently working with UARTDriver, and I have a question on how to access the "live" value of DMA NDTR.
My idea is using a virtual timer that checks the NDTR value for a fixed interval, e.g. 1uS.
I'm using STM32F4-Discovery and currently trying to access the value via:
UARTD2.dmarx->stream->NDTR
However, everytime I printed the value to the console, I always get the maximum value (it never showed the value went down).
Can someone point me to how to properly access the "live" value?
Thank you. ;)
- Sam
Re: Accessing DMA NDTR for STM32F4
It is unlikely you can use virtual timers for intervals like 1uS, even a real timer couldn't do that because ISR latencies.
Note that the interval is rounded up to the next system tick wich is 100uS in most demos.
samtatasurya
Giovanni wrote:It is unlikely you can use virtual timers for intervals like 1uS, even a real timer couldn't do that because ISR latencies.
If that is the case, is there any alternative way I can track the value of DMA NDTR?
Because, even if I slowed down the interval, I always got the maximum value passed to the DMA NDTR and never saw it got decremented.
Thank you.
- Sam
Very complex.
Forget about printing values in real time with 1uS intervals.
I don't know if this could work: use another DMA channel, triggered by a timer, to read NTDR values and store them into a buffer that you can examine later.
I am missing the point of all this anyway.
samtatasurya
Giovanni wrote:Very complex.
The point of what I'm trying to do is to create some kind of a byte tracker for the data that is received via UART.
Because from my understanding, rxend callback only gets called whenever the NDTR reaches 0.
I want to implement a tracker which checks the NDTR on a defined interval, so that my system will know if data transmission gets interrupted in the middle of receiving.
For example, if the NDTR stays on a particular value (>0) for a defined interval, my system will assume that the transmission has been completed instead of waiting for the next bytes until NDTR reaches 0.
Sorry I forgot to mention my intention early on. I hope you would get the idea of what I'm trying to achieve.
Thanks!
Simply use the API with timeout, if the data flow is interrupted or delayed you will get a timeout.
samtatasurya
Giovanni wrote:Simply use the API with timeout, if the data flow is interrupted or delayed you will get a timeout.
I forgot to mention that the ChibiOS version I was using was 3.0.4, which doesn't have the timeout functionalities for UART.
I'll try to use 16.1.4 and see whether I can implement what you suggested.
Thanks!
- Sam
