../../../os/various/shell/shell.c: In function 'shellGetLine':
../../../os/various/shell/shell.c:234:5: warning: implicit declaration of function 'chSequentialStreamRead' [-Wimplicit-function-declaration]
if (chSequentialStreamRead(chp, (uint8_t *)&c, 1) == 0)
../../../os/various/shell/shell.c:242:9: warning: implicit declaration of function 'chSequentialStreamPut' [-Wimplicit-function-declaration]
chSequentialStreamPut(chp, c);
Previously, these were defined as
* @brief Sequential Stream read.
* @details The function reads data from a stream into a buffer.
* @param[in] ip pointer to a @p BaseSequentialStream or derived class
* @param[out] bp pointer to the data buffer
* @param[in] n the maximum amount of data to be transferred
* @return The number of bytes transferred. The return value can
* be less than the specified number of bytes if an
* end-of-file condition has been met.
* @api
#define chSequentialStreamRead(ip, bp, n) ((ip)->vmt->read(ip, bp, n))
* @brief Sequential Stream blocking byte write.
* @details This function writes a byte value to a channel. If the channel
* is not ready to accept data then the calling thread is suspended.
* @param[in] b the byte value to be written to the channel
* @return The operation status.
* @retval Q_OK if the operation succeeded.
* @retval Q_RESET if an end-of-file condition has been met.
* @api
#define chSequentialStreamPut(ip, b) ((ip)->vmt->put(ip, b))Cheers,
jonathan lung
