ADC1, GPT1/14 Conflict on STM32F0
samtatasurya
Post by samtatasurya »
Hi everyone,
I'm using ChibiOS 16.1.4, and the board I'm using is STM32F0 Discovery (STM32F051R8).
I was trying to use both ADC and GPT, but when I was trying to run adcStartConversion() and gptStartContinuous() for the following pairs, my program stopped working:
- ADCD1, GPTD1
- ADCD1, GPTD14
Since I'm using my GPTD3 for other use, and ST requires GPTD2 (when I tried to use GPTD2 st_lld.c raised an error during compilation), I don't know what else to do.
Has anyone run into the same issue? Any suggestion on what to do?
Thanks!
- Sam
Re: ADC1, GPT1/14 Conflict on STM32F0
You can disable the tickless mode in chconf.h, this way TIM2 is free for other drivers, also put tick frequency to 1000.
samtatasurya
Giovanni wrote:Hi,
Thank you for the suggestion, Giovanni.
Just to verify, does that mean if I put the tick frequency to 1000, the system tick boundary will be 1 mS? If originally it is 10000, does that mean the current tick boundary is 100 uS?
Also, is there any chance that I can still use the other GPTs (GPT 1 & 14) together with ADC 1?
One thing that I also notice is that the order of function call results in different behavior.
Case 1 results in the system being stuck around GPT function calls:
adcStart(&ADCD1, NULL);
adcStartConversion(&ADCD1, &adcgrpcfg, samples, ADC_GRP_BUF_DEPTH);
gptStart(&GPTD3, &gpt3cfg);
gptStartContinuous(&GPTD3, GPT3_INTERVAL);
Whereas in case 2, all functions called successfully:
Your insight is greatly appreciated. :D
- Sam
Correct about systick.
About ADC and GPT, I suggest to start driver first, the start conversion, then start the timer. The reason is hidden in the STM32 technical details and quirks.
