Hi. Should I be making separate platform directories for variants of the AVR? In my case, I made, next to the AVR directory, a copy called ATmegaXX4. I've modified the serial_lld.* files because there are two USARTS on that platform.
I notice in the ports/GCC/AVR/chcore.h file, there is a CH_CORE_VARIANT_NAME, but I don't know if I want to try to #if all the variants in the driver code.
AVR variants
Moderator: tfAteba
Re: AVR variants
The AVR support is pretty basic, if you want to extend it to the whole family then you should do something like the STM32 HAL which support all the STM32 sub-families.
It has the following structure:
./STM32 (STM32 generic drivers, common to all).
./STM32F1xx (STM32F1xx specific drivers and capability header).
./STM32F2xx (STM32F2xx specific drivers and capability header).
./STM32F4xx (STM32F4xx specific drivers and capability header).
./STM32L1xx (STM32L1xx specific drivers and capability header).
That "capability header" (a section in hal_lld.h) contains a series of definitions detailing what is present in that specific sub-family, this is an example for the STM32L1xx:
The generic device drivers check the above macros in order to include/exclude parts of the code.
/* Platform capabilities. */
* @name STM32L1xx capabilities
/* ADC attributes.*/
#define STM32_HAS_ADC1 TRUE
#define STM32_HAS_ADC2 FALSE
#define STM32_HAS_ADC3 FALSE
/* CAN attributes.*/
#define STM32_HAS_CAN1 FALSE
#define STM32_HAS_CAN2 FALSE
/* DAC attributes.*/
#define STM32_HAS_DAC TRUE
/* DMA attributes.*/
#define STM32_ADVANCED_DMA FALSE
#define STM32_HAS_DMA1 TRUE
#define STM32_HAS_DMA2 FALSE
/* ETH attributes.*/
#define STM32_HAS_ETH FALSE
/* EXTI attributes.*/
#define STM32_EXTI_NUM_CHANNELS 23
/* GPIO attributes.*/
#define STM32_HAS_GPIOA TRUE
#define STM32_HAS_GPIOB TRUE
#define STM32_HAS_GPIOC TRUE
#define STM32_HAS_GPIOD TRUE
#define STM32_HAS_GPIOE TRUE
#define STM32_HAS_GPIOF FALSE
#define STM32_HAS_GPIOG FALSE
#define STM32_HAS_GPIOH TRUE
#define STM32_HAS_GPIOI FALSE
/* I2C attributes.*/
#define STM32_HAS_I2C1 TRUE
#define STM32_I2C1_RX_DMA_MSK (STM32_DMA_STREAM_ID_MSK(1, 7))
#define STM32_I2C1_RX_DMA_CHN 0x00000000
#define STM32_I2C1_TX_DMA_MSK (STM32_DMA_STREAM_ID_MSK(1, 6))
#define STM32_I2C1_TX_DMA_CHN 0x00000000
#define STM32_HAS_I2C2 TRUE
#define STM32_I2C2_RX_DMA_MSK (STM32_DMA_STREAM_ID_MSK(1, 5))
#define STM32_I2C2_RX_DMA_CHN 0x00000000
#define STM32_I2C2_TX_DMA_MSK (STM32_DMA_STREAM_ID_MSK(1, 4))
#define STM32_I2C2_TX_DMA_CHN 0x00000000
#define STM32_HAS_I2C3 FALSE
#define STM32_I2C3_RX_DMA_MSK 0
#define STM32_I2C3_RX_DMA_CHN 0x00000000
#define STM32_I2C3_TX_DMA_MSK 0
#define STM32_I2C3_TX_DMA_CHN 0x00000000
/* RTC attributes.*/
#define STM32_HAS_RTC TRUE
#define STM32_RTC_HAS_SUBSECONDS FALSE
/* SDIO attributes.*/
#define STM32_HAS_SDIO FALSE
/* SPI attributes.*/
#define STM32_HAS_SPI1 TRUE
#define STM32_SPI1_RX_DMA_MSK STM32_DMA_STREAM_ID_MSK(1, 2)
#define STM32_SPI1_RX_DMA_CHN 0x00000000
#define STM32_SPI1_TX_DMA_MSK STM32_DMA_STREAM_ID_MSK(1, 3)
#define STM32_SPI1_TX_DMA_CHN 0x00000000
#define STM32_HAS_SPI2 TRUE
#define STM32_SPI2_RX_DMA_MSK STM32_DMA_STREAM_ID_MSK(1, 4)
#define STM32_SPI2_RX_DMA_CHN 0x00000000
#define STM32_SPI2_TX_DMA_MSK STM32_DMA_STREAM_ID_MSK(1, 5)
#define STM32_SPI2_TX_DMA_CHN 0x00000000
#define STM32_HAS_SPI3 FALSE
#define STM32_SPI3_RX_DMA_MSK 0
#define STM32_SPI3_RX_DMA_CHN 0x00000000
#define STM32_SPI3_TX_DMA_MSK 0
#define STM32_SPI3_TX_DMA_CHN 0x00000000
/* TIM attributes.*/
#define STM32_HAS_TIM1 FALSE
#define STM32_HAS_TIM2 TRUE
#define STM32_HAS_TIM3 TRUE
#define STM32_HAS_TIM4 TRUE
#define STM32_HAS_TIM5 FALSE
#define STM32_HAS_TIM6 TRUE
#define STM32_HAS_TIM7 TRUE
#define STM32_HAS_TIM8 FALSE
#define STM32_HAS_TIM9 TRUE
#define STM32_HAS_TIM10 TRUE
#define STM32_HAS_TIM11 TRUE
#define STM32_HAS_TIM12 FALSE
#define STM32_HAS_TIM13 FALSE
#define STM32_HAS_TIM14 FALSE
#define STM32_HAS_TIM15 FALSE
#define STM32_HAS_TIM16 FALSE
#define STM32_HAS_TIM17 FALSE
/* USART attributes.*/
#define STM32_HAS_USART1 TRUE
#define STM32_USART1_RX_DMA_MSK (STM32_DMA_STREAM_ID_MSK(1, 5))
#define STM32_USART1_RX_DMA_CHN 0x00000000
#define STM32_USART1_TX_DMA_MSK (STM32_DMA_STREAM_ID_MSK(1, 4))
#define STM32_USART1_TX_DMA_CHN 0x00000000
#define STM32_HAS_USART2 TRUE
#define STM32_USART2_RX_DMA_MSK (STM32_DMA_STREAM_ID_MSK(1, 6))
#define STM32_USART2_RX_DMA_CHN 0x00000000
#define STM32_USART2_TX_DMA_MSK (STM32_DMA_STREAM_ID_MSK(1, 7))
#define STM32_USART2_TX_DMA_CHN 0x00000000
#define STM32_HAS_USART3 TRUE
#define STM32_USART3_RX_DMA_MSK (STM32_DMA_STREAM_ID_MSK(1, 3))
#define STM32_USART3_RX_DMA_CHN 0x00000000
#define STM32_USART3_TX_DMA_MSK (STM32_DMA_STREAM_ID_MSK(1, 2))
#define STM32_USART3_TX_DMA_CHN 0x00000000
#define STM32_HAS_UART4 FALSE
#define STM32_UART4_RX_DMA_MSK 0
#define STM32_UART4_RX_DMA_CHN 0x00000000
#define STM32_UART4_TX_DMA_MSK 0
#define STM32_UART4_TX_DMA_CHN 0x00000000
#define STM32_HAS_UART5 FALSE
#define STM32_UART5_RX_DMA_MSK 0
#define STM32_UART5_RX_DMA_CHN 0x00000000
#define STM32_UART5_TX_DMA_MSK 0
#define STM32_UART5_TX_DMA_CHN 0x00000000
#define STM32_HAS_USART6 FALSE
#define STM32_USART6_RX_DMA_MSK 0
#define STM32_USART6_RX_DMA_CHN 0x00000000
#define STM32_USART6_TX_DMA_MSK 0
#define STM32_USART6_TX_DMA_CHN 0x00000000
/* USB attributes.*/
#define STM32_HAS_USB TRUE
#define STM32_HAS_OTG1 FALSE
#define STM32_HAS_OTG2 FALSE
Re: AVR variants
Part of the problem with AVR is this: The existing AVR refers to the USART constants like "UDE" (I might be making this up). But in the ATmegaXX4 parts, it's "UDE0" and "UDE1". To make a generic driver, there'd be a lot of #if/#else code in the generic driver, it seems. Is that still the best way?
Re: AVR variants
Maybe, but that just makes it harder for the next person familiar with AVR to understand what's going on (they have to see what each of the renamed defines is).
Re: AVR variants
There are instances of incompatible names in the ST headers too. I usually do one of the following:
1) Names normalization.
2) Don't use the headers and redefine the structures in the xxx_lld.h, I do this when the definitions in the vendor files are too dumb to use or plain wrong.
For example:
For example:
/* There are differences in vector names in the various sub-families,
normalizing.*/
#if defined(STM32F10X_XL)
#define TIM1_BRK_IRQn TIM1_BRK_TIM9_IRQn
#define TIM1_UP_IRQn TIM1_UP_TIM10_IRQn
#define TIM1_TRG_COM_IRQn TIM1_TRG_COM_TIM11_IRQn
#define TIM8_BRK_IRQn TIM8_BRK_TIM12_IRQn
#define TIM8_UP_IRQn TIM8_UP_TIM13_IRQn
#define TIM8_TRG_COM_IRQn TIM8_TRG_COM_TIM14_IRQn
#elif defined(STM32F10X_LD_VL)|| defined(STM32F10X_MD_VL) || \
defined(STM32F10X_HD_VL)
#define TIM1_BRK_IRQn TIM1_BRK_TIM15_IRQn
#define TIM1_UP_IRQn TIM1_UP_TIM16_IRQn
#define TIM1_TRG_COM_IRQn TIM1_TRG_COM_TIM17_IRQn
Re: AVR variants
I suppose I can define a normalized USART0 to be USART when there's only one. That might actually not be so bad. Thanks!
