chibios hal without RT
noodlefighter
Post by noodlefighter »
i try to use chibios/hal without rt-kenerl on stm32f103c8t6
but the interrupt does not work(i set a breakpoint in the ISR but never reach there)
everything works well when i use RT OSAL..
ChibiOS_3.0.5(in fact i had tried the latest version 16.1.4)
arm-none-eabi-gcc 5.2.1 20151202
i try to fit the example "testhal/STM32/STM32F1xx/UART" to bare-metal like this..
it only print out a line: "Starting..."
#include "hal.h"
static void txend2(UARTDriver *uartp) {
  (void)uartp;
  osalSysLockFromISR();
  uartStartSendI(&UARTD2, 12, "Running...\r\n");
  osalSysUnlockFromISR();
static UARTConfig uart_cfg_1 = {
  NULL,
  txend2,
  NULL,
  NULL,
  NULL,
  38400,
  0,
  USART_CR2_LINEN,
  0
int main(void) {
//  chSysInit();
  uartStart(&UARTD2, &uart_cfg_1);
  uartStartSend(&UARTD2, 13, "Starting...\r\n");
  while (true) {
    osalThreadSleepMilliseconds(500);
  return 0;
makefile
# Startup files.
include $(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC/mk/startup_stm32f1xx.mk
# HAL-OSAL files (optional).
include $(CHIBIOS)/os/hal/ports/STM32/STM32F1xx/platform.mk
include $(CHIBIOS)/os/hal/boards/OLIMEX_STM32_P103/board.mk
#include $(CHIBIOS)/os/hal/osal/rt/osal.mk
include $(CHIBIOS)/os/hal/osal/os-less/ARMCMx/osal.mk
# RTOS files (optional).
#include $(CHIBIOS)/os/rt/rt.mk
#include $(CHIBIOS)/os/rt/ports/ARMCMx/compilers/GCC/mk/port_v7m.mk
Re: chibios hal without RT
You need to enable interrupts after you perform halInit(), interrupts are disabled on main() entry. See the demo HAL-STM32F407-DISCOVERY.
 * Application entry point.
int main(void) {
   * System initializations.
   * Enabling interrupts, initialization done.
  osalSysEnable();
noodlefighter
thanks a lot. really works! :D
Glad to hear it.
Anyway let us know how it goes, HAL alone is not a common use case, most use the whole package.
