Linking build/ch.elf
build/obj/pwm_lld.o (symbol from plugin): In function `pwm_lld_disable_channel_notification':
(.text+0x0): multiple definition of `Vector80'
build/obj/icu_lld.o (symbol from plugin):(.text+0x0): first defined here
../os/common/ports/ARMCMx/compilers/GCC/rules.mk:238: recipe for target 'build/ch.elf' failed
make: *** [build/ch.elf] Error 1
You can easily reproduce this by just changing the STM32F0xx/PWM-ICU demo to use TIM3 instead of TIM1, and of course changing all occurrences of PWMD1 to PWMD3 in main.c
What might be going on here?
