Possible PAL config casting issue
meatball
Has thanked: 9 times
Been thanked: 2 times
Post by meatball »
Hey all,
I'm making a board.h file for the F429ZI Nucleo-144. It's been going pretty well. When I'm done, and have some basic webserver working, I want to submit it to the offical repo in an effort to contribute, since I saw the Nucleo 144s are not officially in the examples repo.
I'm using Win7 and KEIL 5.16a, and the project builds alright, though I've noticed some warnings that appear as I change the default PAL configuration.
I started my board.h editing task by changing the #def names to match the pin functions that are on the board (mainly ETH and USB OTG). I did this by modifying a board header for the F429 Discovery. It was after I changed the pin names that I noticed some of these compiler warnings about:
os\hal\boards\ST_NUCLEO_F429ZI\board.c(28): warning: #61-D: integer operation result is out of range
Which takes me to
const PALConfig pal_default_config = {
#if STM32_HAS_GPIOA
  {VAL_GPIOA_MODER, VAL_GPIOA_OTYPER, VAL_GPIOA_OSPEEDR, VAL_GPIOA_PUPDR,
   VAL_GPIOA_ODR,   VAL_GPIOA_AFRL,   VAL_GPIOA_AFRH},
Previously, I was able to prevent this warning from appearing by resetting all the arguments from
PIN_AFIO_AF(GPIOA_UART_TX, 7)
to
PIN_AFIO_AF(GPIOA_UART_TX, 0)
for all of VAL_GPIOA_AFRL and VAL_GPIOA_AFRH
So at one point, I was able to clear these warnings by setting all pin AF functionality for the F429 Discovery to default 0.
Now, as I've finished naming all the pins, and am actually setting MODER, OTYPER, to match what the pin type needs, I've managed to avoid seeing many of these warnings as I change back to the actual functionality I need for the Nucleo, for USB and ETH.
But now I've finished the AF configuration, and still need to finish MODER, OTYPE configs. But I don't want to move on until I get this resolved.
Here is my GPIOA setup:
Names are complete
 * IO pins assignments.
#define GPIOA_PIN0                  0U
#define GPIOA_ETH_RMII_REF_CLK      1U
#define GPIOA_ETH_RMII_MDIO         2U
#define GPIOA_PIN3                  3U
#define GPIOA_PIN4                  4U
#define GPIOA_PIN5                  5U
#define GPIOA_PIN6                  6U
#define GPIOA_ETH_RMII_CRS_DV       7U
#define GPIOA_PIN8                  8U
#define GPIOA_OTG_FS_VBUS           9U
#define GPIOA_OTG_FS_ID             10U
#define GPIOA_OTG_FS_DM             11U
#define GPIOA_OTG_FS_DP             12U
#define GPIOA_SWDIO                 13U
#define GPIOA_SWCLK                 14U
#define GPIOA_PIN15                 15U
I/O assignment is not complete yet.
 * IO lines assignments.
#define LINE_BUTTON                 PAL_LINE(GPIOA, 0U)
#define LINE_ETH_RMII_REF_CLK       PAL_LINE(GPIOA, 1U)
#define LINE_MEMS_INT2              PAL_LINE(GPIOA, 2U)
#define LINE_LCD_B5                 PAL_LINE(GPIOA, 3U)
#define LINE_LCD_VSYNC              PAL_LINE(GPIOA, 4U)
#define LINE_LCD_G2                 PAL_LINE(GPIOA, 6U)
#define LINE_ACP_RST                PAL_LINE(GPIOA, 7U)
#define LINE_I2C3_SCL               PAL_LINE(GPIOA, 8U)
#define LINE_UART_TX                PAL_LINE(GPIOA, 9U)
#define LINE_UART_RX                PAL_LINE(GPIOA, 10U)
#define LINE_LCD_R4                 PAL_LINE(GPIOA, 11U)
#define LINE_LCD_R5                 PAL_LINE(GPIOA, 12U)
#define LINE_SWDIO                  PAL_LINE(GPIOA, 13U)
#define LINE_SWCLK                  PAL_LINE(GPIOA, 14U)
#define LINE_TP_INT                 PAL_LINE(GPIOA, 15U)
 * GPIOA setup:
 * PA0  - PIN0                      (input pullup)
 * PA1  - ETH_RMII_REF_CLK          (input pullup)
 * PA2  - ETH_RMII_MDIO             (input pullup)
 * PA3  - PIN3                      (input pullup)
 * PA4  - PIN4                      (input pullup)
 * PA5  - PIN5                      (input pullup)
 * PA6  - PIN6                      (input pullup)
 * PA7  - ETH_RMII_CRS_DV           (input pullup)
 * PA8  - PIN8                      (input pullup)
 * PA9  - OTG_FS_VBUS               (input pullup)
 * PA10 - OTG_FS_ID                 (input pullup)
 * PA11 - GPIOA_OTG_FS_DM           (input pullup)
 * PA12 - GPIOA_OTG_FS_DP           (input pullup)
 * PA13 - SWDIO                     (input pullup)
 * PA14 - SWCLK                     (input pullup)
 * PA15 - PIN15                     (input pullup)
#define VAL_GPIOA_MODER             (PIN_MODE_INPUT(GPIOA_PIN0) |         \
                                     PIN_MODE_INPUT(GPIOA_ETH_RMII_REF_CLK) |      \
                                     PIN_MODE_INPUT(GPIOA_ETH_RMII_MDIO) |      \
                                     PIN_MODE_INPUT(GPIOA_PIN3) |     \
                                     PIN_MODE_INPUT(GPIOA_PIN4) |  \
                                     PIN_MODE_INPUT(GPIOA_PIN5) |           \
                                     PIN_MODE_INPUT(GPIOA_PIN6) |     \
                                     PIN_MODE_INPUT(GPIOA_ETH_RMII_CRS_DV) |        \
                                     PIN_MODE_INPUT(GPIOA_PIN8) |   \
                                     PIN_MODE_INPUT(GPIOA_OTG_FS_VBUS) |    \
                                     PIN_MODE_INPUT(GPIOA_OTG_FS_ID) |    \
                                     PIN_MODE_INPUT(GPIOA_OTG_FS_DM) |     \
                                     PIN_MODE_INPUT(GPIOA_OTG_FS_DP) |     \
                                     PIN_MODE_INPUT(GPIOA_SWDIO) |      \
                                     PIN_MODE_INPUT(GPIOA_SWCLK) |      \
                                     PIN_MODE_INPUT(GPIOA_PIN15))
#define VAL_GPIOA_OTYPER            (PIN_OTYPE_PUSHPULL(GPIOA_PIN0) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ETH_RMII_REF_CLK) |  \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ETH_RMII_MDIO) |  \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN3) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN4) |  \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN5) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN6) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ETH_RMII_CRS_DV) |    \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN8) |  \
                                     PIN_OTYPE_PUSHPULL(GPIOA_OTG_FS_VBUS) |    \
                                     PIN_OTYPE_PUSHPULL(GPIOA_OTG_FS_ID) |    \
                                     PIN_OTYPE_PUSHPULL(GPIOA_OTG_FS_DM) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_OTG_FS_DP) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_SWDIO) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOA_SWCLK) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN15))
#define VAL_GPIOA_OSPEEDR           (PIN_OSPEED_HIGH(GPIOA_PIN0) |     \
                                     PIN_OSPEED_HIGH(GPIOA_ETH_RMII_REF_CLK) |  \
                                     PIN_OSPEED_HIGH(GPIOA_ETH_RMII_MDIO) |  \
                                     PIN_OSPEED_HIGH(GPIOA_PIN3) |        \
                                     PIN_OSPEED_HIGH(GPIOA_PIN4) |     \
                                     PIN_OSPEED_HIGH(GPIOA_PIN5) |       \
                                     PIN_OSPEED_HIGH(GPIOA_PIN6) |        \
                                     PIN_OSPEED_HIGH(GPIOA_ETH_RMII_CRS_DV) |    \
                                     PIN_OSPEED_HIGH(GPIOA_PIN8) |      \
                                     PIN_OSPEED_HIGH(GPIOA_OTG_FS_VBUS) |    \
                                     PIN_OSPEED_HIGH(GPIOA_OTG_FS_ID) |    \
                                     PIN_OSPEED_HIGH(GPIOA_OTG_FS_DM) |        \
                                     PIN_OSPEED_HIGH(GPIOA_OTG_FS_DP) |        \
                                     PIN_OSPEED_HIGH(GPIOA_SWDIO) |         \
                                     PIN_OSPEED_HIGH(GPIOA_SWCLK) |         \
                                     PIN_OSPEED_HIGH(GPIOA_PIN15))
#define VAL_GPIOA_PUPDR             (PIN_PUPDR_PULLUP(GPIOA_PIN0) |     \
                                     PIN_PUPDR_PULLUP(GPIOA_ETH_RMII_REF_CLK) |  \
                                     PIN_PUPDR_PULLUP(GPIOA_ETH_RMII_MDIO) |  \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN3) |     \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN4) |  \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN5) |         \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN6) |     \
                                     PIN_PUPDR_PULLUP(GPIOA_ETH_RMII_CRS_DV) |      \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN8) |   \
                                     PIN_PUPDR_PULLUP(GPIOA_OTG_FS_VBUS) |      \
                                     PIN_PUPDR_PULLUP(GPIOA_OTG_FS_ID) |      \
                                     PIN_PUPDR_PULLUP(GPIOA_OTG_FS_DM) |     \
                                     PIN_PUPDR_PULLUP(GPIOA_OTG_FS_DP) |     \
                                     PIN_PUPDR_PULLUP(GPIOA_SWDIO) |        \
                                     PIN_PUPDR_PULLUP(GPIOA_SWCLK) |      \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN15))
#define VAL_GPIOA_ODR               (PIN_ODR_HIGH(GPIOA_PIN0) |           \
                                     PIN_ODR_HIGH(GPIOA_ETH_RMII_REF_CLK) |        \
                                     PIN_ODR_HIGH(GPIOA_ETH_RMII_MDIO) |        \
                                     PIN_ODR_HIGH(GPIOA_PIN3) |           \
                                     PIN_ODR_HIGH(GPIOA_PIN4) |        \
                                     PIN_ODR_HIGH(GPIOA_PIN5) |             \
                                     PIN_ODR_HIGH(GPIOA_PIN6) |           \
                                     PIN_ODR_HIGH(GPIOA_ETH_RMII_CRS_DV) |          \
                                     PIN_ODR_HIGH(GPIOA_PIN8) |         \
                                     PIN_ODR_HIGH(GPIOA_OTG_FS_VBUS) |          \
                                     PIN_ODR_HIGH(GPIOA_OTG_FS_ID) |          \
                                     PIN_ODR_HIGH(GPIOA_OTG_FS_DM) |           \
                                     PIN_ODR_HIGH(GPIOA_OTG_FS_DP) |           \
                                     PIN_ODR_HIGH(GPIOA_SWDIO) |            \
                                     PIN_ODR_HIGH(GPIOA_SWCLK) |            \
                                     PIN_ODR_HIGH(GPIOA_PIN15))
#define VAL_GPIOA_AFRL              (PIN_AFIO_AF(GPIOA_PIN0, 0) |         \
                                     PIN_AFIO_AF(GPIOA_ETH_RMII_REF_CLK, 11) |      \
                                     PIN_AFIO_AF(GPIOA_ETH_RMII_MDIO, 11) |      \
                                     PIN_AFIO_AF(GPIOA_PIN3, 0) |        \
                                     PIN_AFIO_AF(GPIOA_PIN4, 0) |     \
                                     PIN_AFIO_AF(GPIOA_PIN5, 0) |           \
                                     PIN_AFIO_AF(GPIOA_PIN6, 0) |        \
                                     PIN_AFIO_AF(GPIOA_ETH_RMII_CRS_DV, 11))
#define VAL_GPIOA_AFRH              (PIN_AFIO_AF(GPIOA_PIN8, 0) |       \
                                     PIN_AFIO_AF(GPIOA_OTG_FS_VBUS, 0) |        \
                                     PIN_AFIO_AF(GPIOA_OTG_FS_ID, 10) |        \
                                     PIN_AFIO_AF(GPIOA_OTG_FS_DM, 10) |        \
                                     PIN_AFIO_AF(GPIOA_OTG_FS_DP, 10) |        \
                                     PIN_AFIO_AF(GPIOA_SWDIO, 0) |          \
                                     PIN_AFIO_AF(GPIOA_SWCLK, 0) |          \
                                     PIN_AFIO_AF(GPIOA_PIN15, 0))
Reg macros (unmodified from original, they look correct to me)
 * I/O ports initial setup, this configuration is established soon after reset
 * in the initialization code.
 * Please refer to the STM32 Reference Manual for details.
#define PIN_MODE_INPUT(n)           (0U << ((n) * 2U))
#define PIN_MODE_OUTPUT(n)          (1U << ((n) * 2U))
#define PIN_MODE_ALTERNATE(n)       (2U << ((n) * 2U))
#define PIN_MODE_ANALOG(n)          (3U << ((n) * 2U))
#define PIN_ODR_LOW(n)              (0U << (n))
#define PIN_ODR_HIGH(n)             (1U << (n))
#define PIN_OTYPE_PUSHPULL(n)       (0U << (n))
#define PIN_OTYPE_OPENDRAIN(n)      (1U << (n))
#define PIN_OSPEED_VERYLOW(n)       (0U << ((n) * 2U))
#define PIN_OSPEED_LOW(n)           (1U << ((n) * 2U))
#define PIN_OSPEED_MEDIUM(n)        (2U << ((n) * 2U))
#define PIN_OSPEED_HIGH(n)          (3U << ((n) * 2U))
#define PIN_PUPDR_FLOATING(n)       (0U << ((n) * 2U))
#define PIN_PUPDR_PULLUP(n)         (1U << ((n) * 2U))
#define PIN_PUPDR_PULLDOWN(n)       (2U << ((n) * 2U))
#define PIN_AFIO_AF(n, v)           ((v) << (((n) % 8U) * 4U))
I can't figure out which of these macros is evaluating to be out of range, since the compiler takes me to where these setting are all OR'ed together into a PAL config type (as shown at the very top as the first code snippet). This means it might just be one of these things which are evaluating to some kind of overflowed number. Which one might it be? Is there a better way for me to approach solving this one?
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Re: Possible PAL config casting issue
Post by RoccoMarco »
that board as much others are already supported on trunk and they will be released with next ChibiOS 16.x. Meanwhile you can work on trunk.
Ciao,
RM
PS: Note that STM32 board files are generated using a tool.
https://www.youtube.com/watch?v=HwJqZfITvV0
Try adding U to all numeric constants, that warning is about an signed number becoming negative because the shift.
Apparently the board generator tool is generating some constants without the U, it is a small bug, it will be fixed in next ChibiStudio release.
rew
Has thanked: 2 times
Been thanked: 14 times
Post by rew »
Again someone didn't see the "This file is automatically generated from ... at the top of the board.h file... Maybe make it a bit more prominent?
To me the video does not help me understand what needs to be done to generate a new board.h file.
Apparently you click somewhere, fill in a name for the board,
then you click somewhere else, and fill out names for the pins.
Then another click and you have your board.h which is magically generated.
Board files have been regenerated, fixed the problem with constants and added a warning header.
giovanni
