issue around MS2ST Macros
Tabulous
Has thanked: 7 times
Been thanked: 18 times
Post by Tabulous »
using STM32F101
got system tick set to 50,000(need the resolution in the threads). F101 system tick can only run on 16bit timer.
MS2ST(5000) as per below results in overflowing the systime_t delay varible as this is only unsigned 16bits.
chVTSetI(&tmr1, MS2ST(5000), test1, &msg);
So i assume this is a limitation when the system tick is high these macros dont/can't do what you want........
maybe having some check code around to warn at compile time would be useful.
Re: issue around MS2ST Macros
How would you do that?
Tabulous
Post by Tabulous »
Giovanni wrote:Hi,
Yeah, not really possibly, but you could have runtime asserts if the value calculated is larger that the variable it is been load into and thus would get trucated ?
