This is quite off-topic for this forum but maybe somebody has bumped into this issue here as well.
I'm using a VL Discovery (F1) with Versaloon firmware together with OpenOCD to debug my F2 board. It's working well when using exactly the right versions of things.
I have F4 version of our board as well as the F4 is at least pin compatible with F2. But no matter what I do I can't get OpenOCD to find my F4 target. This is all I get:
$ sudo /tmp/oocd/bin/openocd -f interface/vsllink-swd.cfg -target/stm32f4x.cfg
Open On-Chip Debugger 0.6.0-dev-00406-g0b0281d (2012-02-11-17:00)
Licensed under GNU GPL v2
For bug reports, read
Warn : must select a transport.
Info : OpenOCD runs in SWD mode
DEPRECATED! use 'adapter_khz' not 'jtag_khz'
2000 kHz
DEPRECATED! use 'adapter_nsrst_delay' not 'jtag_nsrst_delay'
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
Info : Versaloon(0x33)by Simon(compiled on Feb 12 2012)
Info : USB_TO_XXX abilities: 0x00000008:0x00000040:0xC0000006
Info : clock speed 2000 kHz
Error: SWD-DP OVERRUN - check clock, memaccess, or reduce swd speed
Error: SWD-DP STICKY ERROR
The last two lines keep repeating really fast.
Any suggestions?
PS. Are the JTAG/SWD pins pin muxed as JTAG in the STM32 boot mode?
