ChibiOS Debug View help please
kb1gtt
Has thanked: 11 times
Been thanked: 2 times
Postby kb1gtt » Mon Jul 11, 2016 8:34 pm
I'm having some troubles with ChibiOS Debug View, I have followed a brief tutorial found here http://www.playembedded.org/blog/en/201 ... ibistudio/ However the results are shown below.
You can see that the board is running, and has stopped in main.c, the ChibiOS Debug View shows no data.
From chconf.h
#define CH_DBG_STATISTICS      TRUE
#define CH_DBG_SYSTEM_STATE_CHECK   TRUE
#define CH_DBG_ENABLE_CHECKS      TRUE
#define CH_DBG_ENABLE_ASSERTS      TRUE
#define CH_DBG_ENABLE_TRACE      TRUE
#define CH_DBG_ENABLE_STACK_CHECK   TRUE
#define CH_DBG_FILL_THREADS         TRUE
#define CH_DBG_THREADS_PROFILING   FALSE
From the console after a make clean, the build. Note the -ggdb -O0 -g3
arm-none-eabi-gcc -c -ggdb -O0 -g3 -mcpu=cortex-m4 -falign-functions=16 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant
From ch.h
#define CH_KERNEL_MAJOR         3
#define CH_KERNEL_MINOR         0
#define CH_KERNEL_PATCH         1
This is ChibiStudio_Preview17, PC is Win7 64bit, this is java version noted below.
C:\>java -version
java version "1.7.0_80"
Java(TM) SE Runtime Environment (build 1.7.0_80-b15)
Java HotSpot(TM) 64-Bit Server VM (build 24.80-b11, mixed mode)
C:\>
Is there something else I need to do to get this to display information?
Has thanked: 876 times
Been thanked: 750 times
Re: ChibiOS Debug View help please
Postby Giovanni » Mon Jul 11, 2016 8:49 pm
hi,
You need to step past chSysInit() or the debugger does not detect the OS because it is not initialized.
kb1gtt
Postby kb1gtt » Mon Jul 11, 2016 8:57 pm
From main.c
int main(void) {
Does that do what you mean about stepping past that function?
Postby Giovanni » Mon Jul 11, 2016 8:59 pm
Step until you are past chSysInit() or place a breakpoint after that call.
kb1gtt
Postby kb1gtt » Mon Jul 11, 2016 9:03 pm
This picture more clearly shows that we have just past chSysInit by a little bit, and still no data in ChibiStudio.
Postby Giovanni » Mon Jul 11, 2016 9:38 pm
Have you clicked the "refresh" button? it is the yellow one on upper left of the window.
The refresh operation can be slowish, depending on the used debugger HW, so it is performed on demand only.
kb1gtt
Postby kb1gtt » Mon Jul 11, 2016 9:53 pm
Ah, press the magic button. I see information now. Thanks for the tips and tricks.
omcdr
Has thanked: 7 times
Postby omcdr » Tue Sep 06, 2016 3:02 pm
I have similar problem, but button "reload" not working, Debug View is empty
My configuration:
Makefile: USE_OPT = -O0 -ggdb -fomit-frame-pointer -falign-functions=16
chconf.h
What I'm missing ?
Postby Giovanni » Tue Sep 06, 2016 3:09 pm
Probably you created a new workspace. You need to set in Preferences the default debugger for "GDB Hardware Debugging" to "Legacy GDB". Without that the plugin is unable to access the target.
omcdr
Postby omcdr » Tue Sep 06, 2016 7:41 pm
I have coppied workspace settings from workspace161.
I set Legacy GDB in preferences, but still the same issue.
I'm using J-link v9 and JLinkGDBServerCL.exe - is there problem ?
Return to “ChibiStudio”
Users browsing this forum: No registered users and 0 guests
